Manual Liftgate Won't Stay Up
NavigatorV8
Ford Explorer XLT 2014
my tailgate lifts are lost in pressure, i need a new set. I´ll take the chance to purchase an extension kit, because the tailgate opened not high enough. Anybody knows a solution?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Power liftgate or manual?
NavigatorV8
it manual. But maybe anyone converted a explorer to an OEM power lift kit?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I haven't heard of "extensions" for these. I'm sure there must be a limit to how far it can open.
VCFP153
Ormond Beach FL
2017 PIU
I'm sure it can open 270 degrees. Question is will it close again after that...
peterk9
Staff member
Moderator
Callsign
VE3
peterk9
Staff member
Moderator
Callsign
VE3
The last sentence in my post above answered this question.
That's what I thought as well until I read his own quote which seemed ask about converting it to a power liftgate.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Right, which you cant do, thats why I had said, you cant do it. Am I missing something?
oojphnh
New York
02 explorer
You will have to remove the 4 screws at the bottom, and then pull the inside panel free for access to the mechanism. If the door is stuck closed, you can manipulate the inside panel loose from the door at the top enough to gain access to work the linkage by hand. It is not fun, but can be done without ruining anything. You may have to get some new 'christmas tree' plastic fasteners if the old ones are too distorted to work.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum.:wave:
Do you have a 5th gen. in addition to your '02 Explorer? Just curious as the '02 liftgate is likely different than the one in the 2014.
