Map light bulb holder? | Ford Explorer Forums - Serious Explorations
Would someone with a 2 gen with a sun roof pull out a map light bulb and read the part number for the holder ( it is on the bottom ). Mine is not readable and I need to get a new one.
Thanks…..
Al, I use a 3175 bulb in mine. it's not an exact fit but it's close enough that it works just fine. the glass is a bit fatter than the stock bulb but it will fit.
Tommy
Tommy
Is this a wedge base bulb? How does it fit in?
Is this not a 3175 bulb?
Isf so, mine is definately not that bulb.
This is the 168 bulb...
Originally posted by rydinhigh
Al the size of the bulb should be in your owners manual.
He wants the bulb holder Part number:D
Thanks, I thought that is what I asked too?
ugh you guys are to damn picky.
Al I can get it to you in about half an hour if no one responds first.
Just to make sure we are on the same page here, you are talking about the silver circle thing that you screw in to hold the bulb up there.
I am talking about the bulb holder.
I hope this is the right part number.... XU5Z 13466 AA
Torrie is sending it today.
Al is this what you are talking about? If so the number on the back was V646 and had another number after that I couldnt read.
The part at the base of the 168 vulb.....
