I recently installed a 75mm mass air flow sensor from Mass Air Systems on my '94 X. To begin with, it would constantly stall at start-up and any time I stopped. I could smell gas and it seemed that the engine was running rich. There was also black soot on the tail pipe. I called MAS and talked to one of the guys there. He said that the unit was calbrated to run using a conical filter and my problems were due to the stock air box being used. I found a 3" IFAB cold air intake system on eBay. I installed the cold air system and left the battery disconnected an hour to clear the computer (not sure if this did any good but though it was worth a try.) Initially, I had the same problem with stalls, however over the last month, the engine has been running better, although it feels like I have lost some low end torque. It hardly stalls unless it is very hot outside or I turn on the AC right after I start the engine. There is still soot on the tail pilpe and my mileage has gone down significantly since installing the MAS. Given all this, I am wondering if the MAS is incorrectly calibrated. I called Mass Air Systems again but nobody is returning my phone calls. I am about ready to pull the unit off and put my stock sensor back on. No use using the MAS if all I am doing is running excessively rich. Any ideas or suggestions?
