Massive surging issue
LakersCentral
Southern California
2014 Explorer Sport
Hey all,
I'm getting some crazy surge-like behavior from my new (~1500 miles) 2014 Explorer Sport. It feels like I'm hitting a rev limiter, and unlike anything I've read about on here. Other surging issues on here seem to deal with loss of power, and usually at a high speed/rpm. This is not that.
I've noticed this issue is worst:
  • in first minute after engine start
  • at very low rpm / speed (less than 10mph)
  • when its cold / humid outside
  • when turning (as in a 90 degree right hand turn onto the street)
  • when angled downhill (like when coming out of a parking lot)
Some of these symptoms may be incidental or coincidental, but I just wanted to list everything in case other people may have experienced the same issues.
I have heard things suggested like: spark plug gap too large, condensation in turbo cylinders, gas pump, etc. But again, these all were suggested for surging issue unlike what I've seen described.
I would take it in to the dealership, but it may be difficult for them to reproduce, as it usually happens at night ;(. Has anyone else experienced this, or have any ideas as to what this could be?!?
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Hey all,
Sounds like a few of us have had this issue, yours seems much more severe, I wonder if you have the oil in the spark plug issue?
LakersCentral
Southern California
2014 Explorer Sport
Oh! i haven't seen anyone mention *oil* in the spark plugs!
Would the symptoms I listed be indicative of getting oil in a spark plug? (I'm quite inexperienced when it comes to anything under the hood)
update: I just saw the thread i believe you are referring to. Maybe [MENTION=157968]FordService[/MENTION] can weigh in on this issue?
Also of note (possibly related?): I am getting very bad gas mileage. People have said the mpg gets better as the engine breaks in, but it seems I am starting off way lower than anyone else even did. It started off as low as 12.9 and went up to 14.1, but now has settled back to 13.8.
LakersCentral
Southern California
2014 Explorer Sport
Just ran a Vehicle Health Report, and my "Oil Life" was at 62%. I only have 1500 miles on my car. If I understand correctly, oil changes only need to be done every 7500 to 10000 miles on these vehicles. If my pace continues, that would put me at ~4000 miles.
So I'm wondering if this is indicative of losing oil... possibly like [MENTION=250716]KYmxracer52[/MENTION] had with it leaking onto his spark plugs.
Riley
'13 XLT 4WD
There is a new TSB for excessive oil consumption on the 3.5L Ecoboost. TSB 14-0113
LakersCentral
Southern California
2014 Explorer Sport
Update: Finally took to dealership (Simi Valley Ford). They couldn't reproduce the issue, so they didn't look at anything. There were 2 other (unrelated) issues to which they said the same thing. Damn them. When i tell you $hit is wrong, it is. Investigate it.
After more of my own research, it appears most likely that this stumbling issue is caused my condensation buildup in the intercooler. Ford's design was poor, and in an attempt to fix their error, they simply put a piece of plastic on the side of the intercooler where moisture was building up.
This reduces airflow, but shouldn't allow that moisture buildup to enter. *Unless* (as was every time I reproduced the issue)- it is cold and damp outside, and I was turning and angled down. I believe this motion allowed that moisture buildup to get in.
I'm no mechanic, but this seems the most likely scenario to fit the conditions and symptoms.
plumbago
2013 XLT EcoBoost
There is a pending law suit on this very same condition against Ford and the EcoBoost motor you should look in to......best regards Plum
dentalpain
Chipley, FL
2016 Ford Explorer Sport
Were you tuned at the time?
I had the same thing happen to my 15 sport 3 days in a row. I am running a 93 oct tune. Cold start in the am (35F) and before the closed loop fuel tables. Stumble under mid throttle 1 minute into the drive. Dealership found nothing day one (no CEL), data logging day three showed nothing unusual.
It has never returned. But its my wifes daily driver so kinda hard to tell.
LakersCentral
Southern California
2014 Explorer Sport
I wasn't tuned... Just straight stock doin it from day 1 off the lot.
[MENTION=209069]plumbago[/MENTION] I've looked into this lawsuit, but cant find much info regarding it. What does "pending" mean in regards to a lawsuit?
rok8man 2017 Ford Explorer Massive Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 2
L Ford Set to Kick-Off Massive Price Promotion Next Week Stock 2011 - 2019 Ford Explorer Discussion 4
F 2017 Explorer Sport takeoff surging Stock 2011 - 2019 Ford Explorer Discussion 8
B 2016+ low speed surging Stock 2011 - 2019 Ford Explorer Discussion 37
T 2016 explorer 2.3 engine surging bad when driving Stock 2011 - 2019 Ford Explorer Discussion 3
S Rolling/Surging Idle w/ AC On (TSB 15-0149) Stock 2011 - 2019 Ford Explorer Discussion 1
Y 2017 Platinum Surging and Stalling Stock 2011 - 2019 Ford Explorer Discussion 3
S Key fob issue Stock 2011 - 2019 Ford Explorer Discussion 0
T Help with Dealer service issue Stock 2011 - 2019 Ford Explorer Discussion 4
S 2018 Explorer limited electrical issue Stock 2011 - 2019 Ford Explorer Discussion 3
H New Member - Possible AC issue Stock 2011 - 2019 Ford Explorer Discussion 4
Mike65 Rearview Camera Issue Stock 2011 - 2019 Ford Explorer Discussion 0
T Weird electrical issue Stock 2011 - 2019 Ford Explorer Discussion 13
S New member here! First time Explorer owner, Ford person. Having an issue... Stock 2011 - 2019 Ford Explorer Discussion 6
D Strut issue Stock 2011 - 2019 Ford Explorer Discussion 9
D 2015 Explorer Brake Issue?? Stock 2011 - 2019 Ford Explorer Discussion 14
M Weird Key Issue (No Key Detected, No Remote Start) Stock 2011 - 2019 Ford Explorer Discussion 22
T ABS issue? Stock 2011 - 2019 Ford Explorer Discussion 1
J 2013 Ford Explorer electric issue Stock 2011 - 2019 Ford Explorer Discussion 6
ISTGradFromPSU 2017 Explorer Driver Side Massage Seat Issue Stock 2011 - 2019 Ford Explorer Discussion 4
S 2017 Passenger side mirror glass issue Stock 2011 - 2019 Ford Explorer Discussion 6
J 2016 Sport Wiring Issue? Stock 2011 - 2019 Ford Explorer Discussion 2
J Issue with 2017 Explorer XLT. Looking for advice or opinions Stock 2011 - 2019 Ford Explorer Discussion 3
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
M Parking brake not engaging / break caliper issue? Stock 2011 - 2019 Ford Explorer Discussion 6
B Starting issue. Engine turns over, won't start until I pull fuse for fuel pump. Stock 2011 - 2019 Ford Explorer Discussion 3
T 2017 Explorer drivers door unlock issue Stock 2011 - 2019 Ford Explorer Discussion 3
AdamWest436 Remote start multi flash issue. Stock 2011 - 2019 Ford Explorer Discussion 0
J 2018 Ford Explorer XLT horn issue Stock 2011 - 2019 Ford Explorer Discussion 4
E VCT issue after timing component replacement Stock 2011 - 2019 Ford Explorer Discussion 6
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M Door lock issue Stock 2011 - 2019 Ford Explorer Discussion 2
W Passenger Heated Seat Strange Issue Stock 2011 - 2019 Ford Explorer Discussion 2
B Very intermittent mirror issue 16 Sport Stock 2011 - 2019 Ford Explorer Discussion 6
W Rear Control Heat Top Vents Issue Stock 2011 - 2019 Ford Explorer Discussion 3
D Hot / Cold blend issue Stock 2011 - 2019 Ford Explorer Discussion 14
T Driver side headlight issue (2019 XLT) Stock 2011 - 2019 Ford Explorer Discussion 4
P Ambient Lighting Issue Stock 2011 - 2019 Ford Explorer Discussion 6
B Noobie with an issue 2017 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 13
S 2013 explorer base AC issue Stock 2011 - 2019 Ford Explorer Discussion 0
I Alternator/battery/cable issue Stock 2011 - 2019 Ford Explorer Discussion 2
J Ford Dealer uses rubber band to fix issue Stock 2011 - 2019 Ford Explorer Discussion 10
I Complicated Key Fob issue 2014 Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
B 14 Explorer RPM Weird Issue Stock 2011 - 2019 Ford Explorer Discussion 7
J 2014 Explorer power lift gate issue Stock 2011 - 2019 Ford Explorer Discussion 3
W Odd Parking Light Issue Stock 2011 - 2019 Ford Explorer Discussion 7
J 2015 Ford Explorer Sport BCM Issue Stock 2011 - 2019 Ford Explorer Discussion 12
K 2011 explorer transmission issue Stock 2011 - 2019 Ford Explorer Discussion 22
N 2018 Escape issue Stock 2011 - 2019 Ford Explorer Discussion 25
B 2015 Explorer Sport HVAC Issue Stock 2011 - 2019 Ford Explorer Discussion 11
Similar threads
