Just purchased a 06 SLT 2wd v6 with a 3.55 and I'm concerned as well about towing capacity as well. The owner of the Ford Dealership convinced me (against my by better judgement) that the package would easily tow the TrailManor 2619 we have been considering. Which come's in at 2,673 lbs (dry weight). Not bad for a hard-shell popup. Now I don't know what I'm going to do. Changing differential gearing is not what I had in mind, but at this stage of the game, it seems I have no choice. Can anyone share info as to the best way to proceed? Ford dealership, or independent mechanic? Costs involved, etc? Thanks, Stash
Did you ask this over on PopupExplorer.com?? I could have sworn I saw this question already this morning...
This is another classic case of the dealership telling the customer anything they want to hear to make a sale. Is the dealership owner going to pay for the transmission rebuild or rear-end rebuild when they wear out prematurely due to the towing? I doubt it. If they will, make sure you get it in writing from him... otherwise, in all honesty, he took you for a ride.
As you probably discovered, your tow vehicle isn't going to be the best tool for the rig you're trying to pull. However, it is rated to pull 3500 lbs right out of the box. Now, take that 3500 lb tow rating, subtract the weight of the occupants in the vehicle (wife, kids, dog, etc), and you'll see how quickly the 'real' tow rating diminishes.
Lets just assume you're driving it alone... 3500 lbs of tow capacity, minus 2673lb weight of the trailer, minus the 1000 lbs of gear (easily... probably more) of gear, food, water, propane, firewood, etc., and you're already over the tow vehicle's rating. Now, include the weight of the wife, kids, dog, strollers, playpens, bicycles, and road entertainment, and you're over by another 500-800 lbs. Taking a cooler for the brown-pops? There's another 100 lbs of tasty fermented goodness with ice. You can see how quickly the weight adds-up.
Stepping up to the 3.73 rear end will bump the tow rating to 5390 or 5210 (2wd/4wd). That'll make a world of difference. The good news is that just about any driveline or transmission shop can do the gear change for less than $1000 (probably closer to $750 per axle). The bad news is that you'll have to either take it to a dealership to have the gear ratio adjusted in the computer to correct the speedometer and shift points, or you could invest in a programmer and manually make the adjustments yourself. Additionally a programmer would allow you to adjust the settings for better performance while towing. The trans would like the newer settings a lot more with the better program IMHO, and you'll like the extra power.
Hope that helps!
