MAX WIDTH? | Ford Explorer Forums - Serious Explorations
MAX WIDTH?
depends how much sidewall you have. the more sidewall, the wider the tire you can use. 35x12.5 or 33x12.5 is fine. shorter and you have to go narrower.
if you find the tire in question on tirerack.com they will give you the manufacturers recommnded rim width range there.
yup. i actually have 285's on 8" wide wheels :D
