mcpherson
- May 26, 2007
- Cumming, GA
- '98 XLT, '88 YJ
Figured this would be just as good as anywhere to document my Jeep build thread.
For as long as I could remember I have always wanted to own a Jeep (dont worry, the explorer still has some plans ahead of it and will not be going anywhere.) So after some searching I located a deal on a Jeep and purchased it. I had all best intention of leaving the orginal engine with carberator and transmission, well on the hour long drive home this thought change very quickly and 2 days later I purchased an XJ donor vehicle for the complete engine, wireharness and computer. As further plans went, I ran some compression test on the XJ jeep and it wasnt looking so good; so the next best thing was to test the YJ engine and voila, it came back with excellent results. It was concluded that I was going to purchase a rebuilt cylinder head (4.0 Cast #7120) and with some modifications mount it on the pre-existing 4.2 YJ block.
Stock Specs:
Engine Swap
- Purchased a donor 95' XJ 4.0 Sport
Transmission Swap
- AW-4 Transmission from an 88' XJ
Misc & Replacement Parts (Other then engine/transmission related)
Soon to be here after mods:
Related Information:
Engine Specific
Transmission Specific
Stock Specs:
- Engine - 4.2L I6, 2-B Carb (160,000+ miles)
- Transmission - TF999
- Trasfer Case - NP231
- Front Axle - Dana 30
- Rear Axle - Dana 35
- Axel Gear Ratio - 3.54:1
- Suspension - Stock
- Tires - 31'
Engine Swap
- Parts List:
- Remanufactured Head Cast#7120 (RockAuto.com)
- Motor Oil (Local Auto Store)
- Spark Plugs (Local Auto Store)
- Spark Plugs Wires (Local Auto Store)
- Distributor Cap (Local Auto Store)
- Rotary Button (Local Auto Store)
- Water Pump - FlowKooler (Quadratec.com)
- Thermostat (Local Auto Store)
- Oil Filter (Local Auto Store)
- Serpentine Belt (Local Auto Store)
- Upper Gasket Set
- Crankshaft Seals (Local Auto Store)
- Electric Fan
- Exhaust Studs
- Electric fan Control Unit (DCControl.com)
- Fuel Pump (RockAuto.com)
Transmission Swap
- Parts List:
- Novak Shifter Assembly for New Process - 231 Transfer Case
- Front & Rear Main Seals
- Filter & Gasket
- Transmission Fluid - 8 Quarts
- Soft Top & hardware - Bestop 54599-15 Supertop Black Denim Soft Top with Tinted Windows (Amazon)
- Cleaner - Bestop Protectant & Vinyl Window Cleaner (JC Whitney)
- Front Floor Mats - PLASTICOLOR (JC Whitney)
- Rear Cargo Mat - PLASTICOLOR (JC Whitney)
- Black Lower Door Hinge Brackets - Smittybilt 7607 (Amazon)
- Black Windshield Hinge Brackets - Smittybilt 7603 (Amazon)
- Black Complete Hood Kit - Smittybilt 7699 (Amazon)
- Extreme Black Sport Handle - Smittybilt 769310 (Amazon)
- FAIRCHILD INDUSTRIES 13 Piece Weatherstrip Kit (JC Whitney)
- XJ Hayes Manual (Local Auto Store)
- YJ Hayes Manual (Local Auto Store)
- BDS Suspension - 3-1/2" Lift Kit w/Shocks
- M.O.R.E. Front & Rear Boomerang Shackle (5/8" lift)
Engine Specific
