mean sound
drshakenbreak
Fort Wayne, Indiana
'92 Sport
i was wondering what makes a stock 4.0 sound like a beefy beast. i like the sound a lot and wanted to know what would be the best thing to buy to make it sound like that.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
ajr2000
Trumbull, CT
93 XLT
Intake, headers, exhaust...
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
I got dual chamber 2 flowmasters on my 01 sport and i removed the intake silencer. And my explorer sounds very mean and tough.
But i also agree with agr2000 Intake, Headers, Exhaust will make it sound beefy.
UtahX
Grand Junction, Colorado
2000 Explorer XLT
Yup, if you got the money get some new headers. The cheaper way would be get an cold air intake kit, and/or muffler.
drshakenbreak
Fort Wayne, Indiana
'92 Sport
what kind of headers and intake? the size in diameter of the exhaust
zoltandaman
some were flrodia
1997 explorer sport
cut off your exhaust
UtahX
2000 Explorer XLT
I'm going with a 2.5 that's all that will fit.
aldive
Elite In Memoriam
1999 XLT
Sorry, nothing will.
floydr007
Binghamton, NY
'99 Sport
record a 5.0 mustang going through the gears, then invest all your money in new speakers for your explorer. play the cd over and over with your windows down.
J What's a high squeal sound mean? Under the Hood 6
R 4.0 surges at idle tested now what does it mean? Under the Hood 11
R.J. what does this mean? Under the Hood 7
D what does undersized bearings mean?? Under the Hood 1
O My Ex failed emissions test. Can someone tell me what these numbers mean? Under the Hood 11
S Dont mean to hog the board Under the Hood 16
D What does this mean P0141 & P0420 Under the Hood 9
S battery light - what does it mean? Under the Hood 2
A Mean Green Alternator Install (w/ pics) Under the Hood 10
C dose this mean my tranny is dead Under the Hood 2
T Mean Green Alternator Under the Hood 2
I Does this mean I need new plug wires??? Under the Hood 6
A What does rebuilding a transmissio mean? Under the Hood 12
M what do the oil numbers mean? Under the Hood 4
R What does blinking O/D OFF light mean???? Under the Hood 32
C What does a gas smell in the oil mean? Under the Hood 18
J Knocking/Taping sound coming from engine bay. Under the Hood 5
J Strange new ticking sound after replacing timing chain tensioners. Under the Hood 14
M 2005 ford explorer xlt sound coming from driver side engine Under the Hood 0
C What is this ticking sound when starting 2004 Explorer? (Video) Under the Hood 8
M Hissing Sound Under Passenger Side, Cold Engine, Hot Day Under the Hood 3
G Grinding or crunching or grinding sound immediately after startup Under the Hood 21
S Engine Sound and Throttle Response Under the Hood 0
R knocking sound only after warmed up at idle Under the Hood 0
B This may sound dumb, but... Under the Hood 2
B High pitched screeching/squealing sound Under the Hood 16
B 1999 V6 SOHC p0174 p0171 "sneeze sound" and rough idle Under the Hood 2
R Rattling sound Under the Hood 4
R Buzzing sound coming from under dash and goes away when you press brake Under the Hood 0
Badspell68 Front end sound when going over bumps -suggestions? Under the Hood 6
C Choking sound Under the Hood 0
T grinding sound, slipping feeling when turning steering wheel...need help Under the Hood 1
C HELP! 94 Ford Explorer won't start, no fuel pump sound, code 543 Under the Hood 8
S Wind Tunnel Sound Under the Hood 1
D Rough sound when turning, and another question? Under the Hood 1
V Wheel making very loud Metal scraping Metal Sound... Audio Clip attached Under the Hood 6
I Need help fast. Short reverberating sound coming from engine after cold soak start. Under the Hood 3
M 99 Moungaineer AWD Front End Grinding Sound Under the Hood 0
R Can the EGR valve cause the "Moose Sound"? Under the Hood 1
B Chirpping sound at cold startup? Under the Hood 0
F 1997 explorer 5.0 V8 missing intake vacuum hose errati idle hissing sound code P0171 Under the Hood 11
M Ok, I know I'm going to sound crazy, but how... Under the Hood 20
O Oil viscosity and engine sound Under the Hood 39
J 2002 Ford Explorer XLT problems, Clicking sound? Under the Hood 0
G whistling sound Under the Hood 4
3 Dripping/gurgling sound from heater core? Under the Hood 1
3 Marble sound from oil pan at idle only? Under the Hood 7
m4dc0w High pitch whining sound under hood in hot weather Under the Hood 1
Badspell68 Strange Sound - Just after oil change to Synthetic? Under the Hood 16
J Not sure what sound this is... Under the Hood 35
Similar threads
