Megapost on Explorer Transmission Rebuild
dubrike
Atlanta
2002 Explorer XLT
Hello everyone,
I recently rebuilt the transmission on my 165k 2002 Ford Explorer, saving around $2000. I have taken videos on the entire process, and I have all the information needed. I will be updating this post as I edit the videos and upload them.
I don't know how many people are interested in such complex repair. Please post any question or interest in the subject.
Transmission types:
Ford Explorers come with the 5R55S and 5R55W. These two transmissions are almost exactly the same, only having small size difference in two internal gears, which does not affect any of the procedures necessary for rebuild. These transmissions are also found in Mustangs and Rangers.
The 5R55N and 5R55E are very similar to S/W but have different valve body and therefore cases. Some Lincoln and Jaguar have this transmission. Do not buy anything that is specific for these two.
Symptoms:
- The car took a long time to shift to most gears, specially 2nd and 5th.
- Took around 10 seconds to engage to D and R, unless I got to 3000 RPM, engaging very violently.
- I would randomly lose power, just like if I changed to N in the middle of the road.
- Absolutely no codes or engine light.
The problem:
- No transmission flush (at least to my knowledge) after 165k miles.
- All gaskets and rubbers were hardened and shattered because of the very old burnt fluid.
- Worn servo bores responsible for shifting problems, (fixed with new case).
- Sticky oil pump valve responsible for delayed engagement, (redesigned replacement came with Transgo kit).
- Internal clutches although none were burnt, the friction material was almost gone in all of them.
These transmissions all have the same "servo bore problem". The servos are metal pieces shaped like an umbrella. They move in and out thanks to fluid pressure. After years of use the servo carves a bigger hole in the aluminum case, allowing oil to scape through the bigger hole.
To solve this problem:
you can re-sleeve the case which requires you to take the case out.
In this video a professional drills and installs the only sleeve kit sold on eBay for $380. https://www.youtube.com/watch?v=BW8eUe5VzOw
Instead, I bought a case that was already re-sleeved for $265. I took no risk in drilling my case and it is cheaper than doing it yourself.
OR
you can buy modified servos with a o-ring installed around them, which can be done from the outside.
http://www.fordservoboretransmissionfixsolution.com/
This solution does not last forever, and does not fix any other internal problem.
PDFs:
Removal:
https://drive.google.com/uc?id=0By4YZG4K4CV2Q1g3SkJ0OFNWamM
Rebuild:
http://downloads.bustedfingermotorsports.com/Ford Transmission Manuals/5R55W.pdf
All parts:
http://www.atpnz.co.nz/admin/uploads/5R55W.pdf
Necessary parts:
Ford 5R55W 5R55S Transmission Overhaul Deluxe Rebuild Kit 02-ON Mercury Lincoln $275 on eBay
Rebuilt Torque Converter $170-$30=$140returning the old one on Autozone
Transgo Shift Kit $65 on eBay
5R55S 5R55W Ford/Mercury UPDATED Transmission Case $256 from eBay's powertrainpartsplus
Transjel $11
MerconV Transmission Fluid 12x$6=$72
+$275
+$140
+$65
+$256
+$11
+$72
= $819
Necessary tools: (that you get to keep)
Socket kit, of course.
Torque wrench.
Pick set.
WD-40
Snap Ring Pliers $7
Dial Indicator $12
Transmission adapter for jack $65
Videos:
Disassembly:
Servo explained:
More videos coming..
The car has been working PERFECTLY 100%. It feels really good knowing that I was able to fix it. ^^
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Sounds good. To begin, what problem did you have, and what codes? Also does this involve sleeving the main case?
dubrike
Atlanta
2002 Explorer XLT
How much did the tools needed to perform the rebuild cost?
The tools I needed were pretty standard. There's a Ford tool to get the oil pump out, but most people do not use it :D. The prices are updated now.
5whiskey
North Carolina
2002 Ford Explorer
Subscribed. My tranny feels kind of weak and sometimes slips for a half second on a shift (mostly going into third)... but I don't have the major issues that you reported. I'm gonna ride on mine a little longer before I make repair plans, but I'm pretty sure I'll eventually need this.
JoshMcMadMac
Waynesboro, PA
2002 Mercury Mountaineer
It looks like you should add in ~$300 for a new solenoid pack. This is an awesome write up for doing it yourself, although personally I think I would stick with buying a remanufactured ETE transmission for ~$1600.
dubrike
Atlanta
2002 Explorer XLT
I didn't have the symptoms of a bad solenoid, so I didn't replace it. If it ever fails it would take an hour to replace. There's no need to take the tranny down.
I called several shops around the Atlanta area and they all told me it'd be about 2700$ for a rebuilt transmission, and I'm guessing they would charge me more for installation..?
JoshMcMadMac
Waynesboro, PA
Original solenoids fail, sooner or later. If going through the effort of rebuilding the transmission, it is definitely advisable to replace all of the parts that are prone to failure.
I cannot speak to rebuild costs in your area. I personally encourage the use of ETE transmissions through RockAuto. A properly remanufactured 5R55 transmission with an excellent warranty can be had through them for ~$1600.
dubrike
Atlanta
2002 Explorer XLT
I agree. If you are not going to enjoy rebuilding it yourself you should't do it.
EXPLORER04
Buffalo, NY
04 XLT
This is the route i went. $1400 from rockauto and you can use the 5% discount code. Plus cant beat the 3yr unlimited mileage warranty.
mikeinri
04 Explorer, 94 XLT (RIP)
I applaud this thread. Anything that can demystify an auto tranny, even if having the work done by someone else, is priceless!
Mike
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
Did you have prior experience with rebuilding transmissions?
dubrike
Atlanta
2002 Explorer XLT
No. I have done some things in my car such as wheel bearing, alternator, and spark plugs. I'm just a college student.
drdoom
VA
Dub have you seen my 5R55E thread?
dubrike
Atlanta
2002 Explorer XLT
That's awesome. Now that I've taken one apart I know the big challenge (and accomplishment) it is to rebuild a AT. Did everything work fine after the rebuild?
dubrike
Atlanta
2002 Explorer XLT
So is anybody interested on more videos? I don't have much free time anymore. I'll make them if requested.
drdoom
VA
Yes, I have over 60, 000 miles on that build.
ICoull
Castlegar, BC
2003 Explorer & Aviator
I used a bearing puller [the split halves type] to clamp on to the oil pump shaft and then pulled it with the usual two jaw type puller. Worked very well.
D 04 Explorer EB reading lamp issue Stock 2002 - 2005 Explorers 1
K Explorer 2004 v8 4.6L, limited, transmission flush Stock 2002 - 2005 Explorers 3
M 2002 Explorer Sport 4WD 2 door Stock 2002 - 2005 Explorers 0
E 5r55s 2003 explorer year interchange Stock 2002 - 2005 Explorers 1
S 2003 Ford explorer xlt quarter window glass Stock 2002 - 2005 Explorers 0
E 03’ 4.0 into an 04’ 4.0 Explorer Stock 2002 - 2005 Explorers 1
S 2003 ford explorer charing issue fusable link replacement? Stock 2002 - 2005 Explorers 1
B 2002 Explorer Rear Camber Issue Stock 2002 - 2005 Explorers 11
V 2005 Explorer pdf manual? Stock 2002 - 2005 Explorers 2
W 04 explorer Stock 2002 - 2005 Explorers 4
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
T 03 Eddie Explorer electric seats Stock 2002 - 2005 Explorers 1
M 2005 ford explorer remote Stock 2002 - 2005 Explorers 3
T 04 explorer Stock 2002 - 2005 Explorers 8
Y Custom door chime for 2005 Explorer Stock 2002 - 2005 Explorers 4
F Multifunctional switch 2004 explorer Stock 2002 - 2005 Explorers 1
J 2004 Ford Explorer Issue Stock 2002 - 2005 Explorers 2
M Cold start 02 explorer Stock 2002 - 2005 Explorers 0
E Hey everyone! 2002 Ford Explorer tire options? Stock 2002 - 2005 Explorers 9
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
S Hi im shawn trying to figure out the rumbling sound from breather box 2003 ford explorer xlt Stock 2002 - 2005 Explorers 2
F 2004 ford explorer Just hear clicking when trying to turn over Stock 2002 - 2005 Explorers 10
W 2003 Ford explorer misfire Stock 2002 - 2005 Explorers 1
S Will 2000 fit 2002 transmission explorer Stock 2002 - 2005 Explorers 1
I 2002 Explorer won't turn over Stock 2002 - 2005 Explorers 8
A 2005 Explorer V6 4.0 Timing Chain Question Stock 2002 - 2005 Explorers 2
V 03 Ford Explorer trouble Stock 2002 - 2005 Explorers 1
J 4x4 Problems on 2002 Explorer Stock 2002 - 2005 Explorers 7
P 2003 Ford Explorer auto trans Stock 2002 - 2005 Explorers 2
S 04 Explorer V6 PATS and PCM connections Stock 2002 - 2005 Explorers 2
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
F Need Advice 02 Ford Explorer high XLT V6 4.0 L Stock 2002 - 2005 Explorers 4
M 2004 Explorer Odometer Flickering and Oil Pressure Gauge not working Stock 2002 - 2005 Explorers 0
B 02 Explorer XLT: I turn the ignition off and the radio turns off Stock 2002 - 2005 Explorers 3
J 2002 Ford Explorer 4.0 Stock 2002 - 2005 Explorers 4
F 2003 explorer won’t start Stock 2002 - 2005 Explorers 4
B 02 Explorer: Passenger side door ajar switch work on drivers side Stock 2002 - 2005 Explorers 3
B 02 Explorer XLT: Key in Ignition Chime Stock 2002 - 2005 Explorers 1
B 2002 Explorer: How to remove cabin fusebox? Stock 2002 - 2005 Explorers 2
M Battery saver relay part number or relay type for 2004 Explorer? Stock 2002 - 2005 Explorers 1
M 2002 Explorer 5R55W Trans Won't Go Into Any Gear, No Codes Stock 2002 - 2005 Explorers 1
J 2002 explorer XLS Flex Fuel Turns Won’t Start Stock 2002 - 2005 Explorers 1
G 2003 Explorer sport 2dr 4wd Leaf spring Stock 2002 - 2005 Explorers 3
J 2005 Explorer CB Instal Stock 2002 - 2005 Explorers 1
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
J 02 EXPLORER 4X4 HIGH LIGHT FLASHING Stock 2002 - 2005 Explorers 2
R 2005 Explorer 4.6 P1237 and P0191 Fuel Pump Stock 2002 - 2005 Explorers 0
J 2002 explorer turn signals Stock 2002 - 2005 Explorers 0
B 2005 Explorer shifter loose Stock 2002 - 2005 Explorers 5
Similar threads
