1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
Just like happened to many others, my 5.0L started leaking coolant from the top corners of the timing cover at around 140K. About 10K after the repair the leak returned. This week I finally decided that enough is enough and tore everything down for a second time. Found that the narrow section of the paper gasket next to the coolant passage on the passenger side was broken. My theory is that the bolts lost some torque and this allowed the hot pressurized coolant to seep under the gasket and damage it.
A few days ago I discovered that one of the engine builders (Street Strip Racing) sells a steel gasket, which I purchased. I now see that it's not a real gasket, but simply a 20-mil thick piece of sheet metal, stamped just like the paper one. They advise to apply a thin layer of RTV to both sides and 'promise' that it will never fail. For sure, that steel won't fail, but will it seal? Unlike a real gasket there is nothing to compress, except for the applied RTV. And what prevents that RTV from being squeezed out when torquing the bolts? In fact, I can't see any difference between using this 'gasket' and simply applying RTV between the block and the timing cover and nothing else. I am now scratching my head, trying to decide whether to use this thing or gamble on the paper gasket again. Any opinion will be appreciated.
