MFT Screen touch points unusable | Ford Explorer - Ford Ranger Forums - Serious Explorations
timoconn
Location
VA
Fairfax, VA
2018 Explorer Platinum
My touch screen is not selecting what I'm touching. For example touching Set as destination will select set as Way Point. Does the screen need recalibration? Would this type of issue be covered under the extended APIM warrenty?
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Have you tried a Master Reset?
peterk9
Staff member
Moderator
Callsign
VE3
Yes, no change
If that didn't fix it I don't think there is any sense in disconnecting the battery since the Master Reset set the APIM back to factory defaults. If the issue is the APIM then it should be covered by the extended warranty depending upon the vehicle's build date. I did some checking and it includes Explorers up to and including 2014.
jmr061
Wisconsin
16 Exp Sport
Do a screen calibration.
FordIVTteam
Official Ford Rep
Dearborn, MI
Ford Explorer
Hi timoconn,
If the cause of the issue is determined to be the APIM, it will be covered. I suggest visiting a dealer for assistance: https://owner.ford.com/dealer-locator.html
Shaay
peterk9
Staff member
Moderator
Callsign
VE3
timoconn
Location
VA
Fairfax, VA
I figured it out. It was the Proclip mount that I have had installed for the last three years. It was applying pressure on the screen.
BTW I did try calibrating but didn't start because the onscreen instructions wanted me to press "ESC" to save changes. Not sure how that would be done.
