thestumper
- August 28, 2013
- Pittsburgh, PA
- 2013 Ford Explorer Sport
So... I've read all the posts complaining about the MFT usb indexing issues. I was experiencing the same thing with my "classic" 5G Ipod (disk based). It seemed like every time I turned the car off for more than an hour or so, I would have to suffer through the infamous "Indexing.... Building Commands" process which would last as much as 15-20 minutes. As it turns out, I have a 32Gb iPhone (flash based) that I'm not using at the moment, so I loaded it up with the EXACT same music library on my 5G disk iPod, turned off the phone and blue tooth, and decided to experiment.
My findings: over a 48 hour period, I have had NO indexing or command building issues. It works perfectly every time. 5 seconds after powering on the car, I have USB voice commands.
My initial assumption was the since my 5G iPod is at least six years old, the battery was probably and was shutting down when I turned off the vehicle for more than an hour or so. When power was reapplied, the iPod must be cold booting and MFT is seeing it as a new device.....
Wrong.
The other part of my 'science experiment' was giving the old 5G a full charge and seeing how long the charge would last. After 48 hours, I've lost maybe 5%. Plenty of juice. HOWEVER... I did noticed that on extended shutdown, the old 5G disk iPod would go into a "sleep" mode and was essentially going through a cold boot process even thought there was plenty of battery. The flash based iPod Touch and iPhones don't do go through this same process.
Therefore... I summarize that the sleep/reboot process is causing an MFT re-index on older iPod disk-based devices. It sees it as a new device coming online and assumes that it needs to reprocess all of the information.
Would anyone from the IVT/Ford team care to comment on this? Heck, would anyone at all care to add to the discussion....
Note: my next test will be an iPod Touch; flash based without the phone. i'm guessing that it will behave properly, like the phone, because it does not have the same 'sleep' mode that the disk-based iPod has.
Wrong.
