MFT v3.6.2 is now available
Kirby Baker
Michigan
2013 Ford Explorer Sport
Took 2 installations to get mine done. First one reported a corrupt file on the USB device. 2nd attempt worked, or appears to have worked. didn't test the backup camera yet. It blew away my phone connection and phone book though, so had to re-sync all the contacts and re-enable 911 assist.
kaelin
Ohio
2013 Explorer Sport
Can someone snap a picture of the curved lines? my 2013 with BLIS but not active park assist has always only shown straight lines. I just want to see what I'm looking for and maybe I'm misunderstanding something.
Not sure about the limited but I don't think the 2013 Sport has the curved lines even with BLIS. At least mine doesn't on 3.5.1
roamingphantom
NYC
2013 EX Limited, 302A
My Limited does have the curved lines. Will check this afternoon if its still there with 3.6
13Sport
Los Angeles, CA
2015 Explorer Sport
The curved lines also appear on vehicles with BLIS, not just Active Park Assist.
I have BLIS and I do not have curved lines. They are only available with Active Park Assist (which has the steering sensors for parallel parking)
Bryceb
Acworth, GA
2013 Explorer Limited AWD
Thanks.. same for me. BLIS but not Active Park Assist
this is what I see.. the straight lines and blocks.
and these are my options for camera
mistertoo
Woodcliff Lake, NJ
2013 Explorer Sport
Downloading
I have been trying to download the update from Ford and it has been over an hour and am still at only 38%. Anybody else having this problem?
jrmexplorer
2011 Limited
As others (PeterK9) have mentioned, the belief is that the curved lines are available for those models with active park assist. Those models with active park assist have a steering angle sensor that detects the position of the steering wheel, which is needed to park your car, but which also allows the system to determine the curvature of the lines.
I'm not sure how true this is, as I've heard stories from others w/out park assist that have the curved lines (or think they do), but it sorta makes sense from a technical point of view.
For the record, I have the curved lines, and I also do have the active park assist.
Riley
'13 XLT 4WD
I drive a '13 Sport at work and it has the curved lines as does another one I've been in. Both with BLIS and no Park Assist.
Squirrely
2013 Ford Explorer XLT
The Wifi Keyboard problem is still present for me, but in a different form. Whereas before the number pad was grayed out, along with some of the keys, I now cannot enter anything after the 10th character on a password.
13Sport
Los Angeles, CA
2015 Explorer Sport
I find this really hard to believe. Take a picture of the inside where the tow/auto P switches are, and then of the screen showing the curved lines. I've never seen any Explorer w/ curved lines that didn't have Active Park
13Sport
Los Angeles, CA
2015 Explorer Sport
I asked this question last year, and Cory answered, the active guides are definitely with the active park assist feature.. see the below post
http://www.explorerforum.com/forums/showpost.php?p=2895281&postcount=11
"w1kedz,
The active guide lines are only available with the active park assist. This is partly because with the extra sensors installed (needed for park assist) it also detects to the side and can verify the area is clear of obstructions in the intended path of travel.
Cory"
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
For a picture of what the active guidelines look like for reference, see this thread:
http://www.explorerforum.com/forums/showthread.php?t=361650&page=2
as submitted by VinceL (3rd post down) - although his look a bit different than mine IRC (his are white and mine IRC are translucent green, yellow and red)
-J
I already posted a picture in this thread (post 39). I believe the one Vince posted was pre 3.5.1 and mine was post 3.5.1 was installed. You can see the differences in the screens. Not sure what it looks like with the 3.6.2 update.
peterk9
Staff member
Moderator
Callsign
VE3
SYNC Website
I just tried again to check on my update availability and see that the site is down. Perhaps they took it down just for me so that they can add the update link for my use. :D
wadge
Northern Ontario
2013 Explorer limited
I just downloaded and installed the new update without issue. Hopefully the update cures my navigation issues.
Try refreshing your browser when you go to the site. It took me a couple of tries.
pingbling23
2012 Explorer Limited 4x4
took 7 minutes to download the file, off to the explorer to install it.
13Sport
Los Angeles, CA
2015 Explorer Sport
F V2.11 MFT Update Available on SYNCMyRide.com 2011-2016 My Ford Touch / In Vehicle Technology 157
K MFT(Sync2) to Sync3 V3.4 Upgrade Minor Issue 2011-2016 My Ford Touch / In Vehicle Technology 5
G MFT Sync 2 to Sync 3 Screen Stays On While Car is OFF 2011-2016 My Ford Touch / In Vehicle Technology 8
deewan MFT trouble dialing using iOS 13 2011-2016 My Ford Touch / In Vehicle Technology 2
E Sync 2 with MFT failing. How can I cost effectivly upgrade to Sync 3? 2011-2016 My Ford Touch / In Vehicle Technology 3
J Similar compatible alternative to MFT? 2011-2016 My Ford Touch / In Vehicle Technology 1
D Gremlins in MFT 2011-2016 My Ford Touch / In Vehicle Technology 0
J Sync 2 MFT APIM Replacement / Repair 2011-2016 My Ford Touch / In Vehicle Technology 1
D MFT update trouble and help needed 2011-2016 My Ford Touch / In Vehicle Technology 1
D Anyone use the Waze app with their MFT 3.8 or 3.10? 2011-2016 My Ford Touch / In Vehicle Technology 12
I MFT Entertainment Unavailable / Off Message 2011-2016 My Ford Touch / In Vehicle Technology 7
O Restarting MFT using "Seek >> + Power" (also for Sync 3) 2011-2016 My Ford Touch / In Vehicle Technology 0
E 2015 MFT 8" No NAV - Upgrade ideas to get Android Auto 2011-2016 My Ford Touch / In Vehicle Technology 6
I Sync 2 w/ MFT - iOS11 iPhone Compatibility 2011-2016 My Ford Touch / In Vehicle Technology 15
9 2012 MFT w/ Nav - Stuck on v2.11 2011-2016 My Ford Touch / In Vehicle Technology 5
Jon M This is new...Sync/MFT issue 2011-2016 My Ford Touch / In Vehicle Technology 6
J Upgrading to 8" Sync MFT on 2016 2011-2016 My Ford Touch / In Vehicle Technology 5
Jon M MFT/SYNC/Nav issues 2011-2016 My Ford Touch / In Vehicle Technology 0
S MFT with Speedcams, how ? 2011-2016 My Ford Touch / In Vehicle Technology 3
B Samsung S8 Plus and MFT 2011-2016 My Ford Touch / In Vehicle Technology 4
Daheim111 A "how to" to not have problems with MFT ? 2011-2016 My Ford Touch / In Vehicle Technology 7
2 MFT Update V3.10 2011-2016 My Ford Touch / In Vehicle Technology 150
S 2013 Limited MFT forgot second key 2011-2016 My Ford Touch / In Vehicle Technology 3
S 2016 SONY MFT - weird behavior 2011-2016 My Ford Touch / In Vehicle Technology 7
M Cannot update MFT 2.11 2011-2016 My Ford Touch / In Vehicle Technology 26
A Downgrading from (8" MFT with Nav) to (4.2" non-MFT) 2011-2016 My Ford Touch / In Vehicle Technology 50
T USB Drive Application Error/MFT Crash 2011-2016 My Ford Touch / In Vehicle Technology 8
T MFT Screen touch points unusable 2011-2016 My Ford Touch / In Vehicle Technology 9
L Clever MFT feature 2011-2016 My Ford Touch / In Vehicle Technology 4
B MFT 3.8 IOS 9.3 sync drops connection mid call 2011-2016 My Ford Touch / In Vehicle Technology 0
Sgt1411 MFT v3.8 and iOS10 Issues 2011-2016 My Ford Touch / In Vehicle Technology 65
D MFT for South America - spanish (not Spanish Spain) 2011-2016 My Ford Touch / In Vehicle Technology 5
M iPhone 6 SE and MFT 2011-2016 My Ford Touch / In Vehicle Technology 3
Z MFT Slow when iPhone paired 2011-2016 My Ford Touch / In Vehicle Technology 1
M MFT update question around versions 2011-2016 My Ford Touch / In Vehicle Technology 2
B Want to upgrade from 4.2 to MFT 2011-2016 My Ford Touch / In Vehicle Technology 11
C MFT in german 2011-2016 My Ford Touch / In Vehicle Technology 6
fyrfyter612 MFT problem...anyone else? 2011-2016 My Ford Touch / In Vehicle Technology 0
P Nav stopped working after MFT update 2011-2016 My Ford Touch / In Vehicle Technology 23
F MFT automatically switching to phone Yellow menu 2011-2016 My Ford Touch / In Vehicle Technology 2
1 MFT 3.8 bug and downgrade to 3.7.11 2011-2016 My Ford Touch / In Vehicle Technology 36
G Buying a 2012 Explorer - Nervous about MFT Issues (please advise) 2011-2016 My Ford Touch / In Vehicle Technology 7
N Responding to Text Messages via MFT 2011-2016 My Ford Touch / In Vehicle Technology 1
S SYNC MFT - Interesting USB Input Discovery 2011-2016 My Ford Touch / In Vehicle Technology 2
S SYNC MFT - Browsing Music vs Files 2011-2016 My Ford Touch / In Vehicle Technology 2
T MFT Performing Scheduled Maintenance Again... 2011-2016 My Ford Touch / In Vehicle Technology 3
blwnsmoke Upgrading from MFT/Sync 2 to Sync 3 2011-2016 My Ford Touch / In Vehicle Technology 199
S Sync MFT Browse Memory for USB 2011-2016 My Ford Touch / In Vehicle Technology 3
J 2016 Explorer with MFT - Add Climate Control to Instrument Cluster 2011-2016 My Ford Touch / In Vehicle Technology 25
J MFT SYNC 3.8 SIRI Eyes Free - Avail. on SYNCMYRIDE.COM for 2011-2015 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 330
Similar threads
