ah64aviator
- August 31, 2011
- Enterprise, AL
- 2011 Explorer Limited
Thanks Fordy!
Hit the "House" botton on the bottom of the screen (bottom middle - it is in between Radio and Climate). Once you hit that a little menu should pop up to change the display layout, and then select the top one. You will then be able to see your wallpaper and the layout will be a little different.
