hannibalhector
- April 4, 2011
- Bronx, NY
- 2011 XLT
The following is a reasonable wishlist of fixes/modifications that would drastically improve the overall MFT experience:
Reset Button
I can't count on all my fingers and toes how many times my MFT has frozen up on me and remained that way until I turned the car off then back on. One time it even remained on after I pulled the key out! An actual button or perhaps some sequence of button presses on the streeting wheel should be able to perform a hard restart of the MFT system.
Improved ipod playback
This is in my opinion the biggest knock on the MFT system. The clunky browsing method for the ipod. You should not have to go back to square one whenever you want to browse a playlist that you're currently in! It should also not take upwards of 8 secs to load all the playlists and their contents. Finally, the page scrolling is horrendous! If you hit the down arrow 10 times quikckly, you can drive a quarter mile before the damn thing catches up to you. Unacceptable!
DVD playback
Every aftermarket headunit out there offers this... no brainer!
Improved overall performance
after about a week or so after buying my ex, I felt like the MFT system was the Vista of the Sync systems. Where MS/BSquare dropped the ball big time and will probably make an amazing system in newer models. Hopefully these minor updates will be better than just a 'service pack'
More options and settings!
If the voice control is to blame for the lag in MFT, then an option to disable it altogether should be implemented!
An expansion of phones that have support txt messaging on MFT is way overdue!
Those stupid scheduled maintanance shutdowns that tend to kick in while im in the middle of a 40 mile trip should be forewarned at least one hour prior. That way I don't get lost while I have a route punched in. no brainer???
There are several othe ritems that require revision on this ghastly MFT system. Fixing the above mentioned glitches/annoyances would put a smile on my face from ear to ear. I sincerely hope someone who has the ability to get any or all of these suggestions is reading Thanks!
Reset Button
DVD playback
