Michelin Tires
Hammertime3
Seaford, De
2013 Ford Explorer XLT
What can I expect from the Michelin tires on my '13 Exlporer? Seem to ride OK, but what about mileage. Local tire dealer said to look for 50-60K out of them. They get rotated every oil change.
Bob Allen
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Bob Allen
A lot would depend upon how you drive. Usually OEM tires are not built for high mileage but for quietness and comfort to help sell the vehicle they are on. I think 60K may be pushing it. I also rotate the tires twice a year when I change the Winter/All season tires. I insist they only be rotated front to back and not crossed.
With my current driving, the tire's 'Best Before Date' may arrive before the tread wears down.:D
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Not sure on the michelins but with the factory tires, I'll have 40,000 on them tomorrow with 5-6mm left on each one. I'll have 53-55,000 miles on them before I change them out.
Jwhcars
Lebanon Pa
2014 Explorer XLT AWD
I rotate my tires every 5,000 miles. I feel it is even more important to do this on a vehicle such as our Explorers.
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
On prior Explores with Michelin tires (Cross Country model), they lasted about 40,000 miles. Great tires, but wet traction went away the last several thousand miles.
On my 2011 Limited, I go just over 55,000 miles on the Hankooks. Replaced them a little early (maybe could have done another 5,000 miles) but I wanted fresh tread for the pending winter.
Joeymustang
Salt Lake City, Utah
2011 Explorer XLT
Same here. I'm about 300 miles shy of 40,000 and tires are still holding up incredibly well. I think they'll last to about 55k like blwnsmoke says :thumbsup:
Hammertime3
Seaford, De
What brand were your "factory" tires? Mine came from the factory with the Michelins on.
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
I have a set of Michelin X-Ice tires (different vehicle) that are on their 7th winter. They have plenty of tread left but their winter performance has considerably dropped. They are probably equivalent to a mid-grade all season tire now.
I'm going to continue to run them through the summer and replace them before next winter.
peterk9
Staff member
Moderator
Callsign
VE3
The Limiteds come with the Hankooks, the XLT with the Michelin and I forget what the Base model comes with. I think it is Goodyear. If you order the optional 20" wheel then I believe it will come with the Hankook tire as well.
Azazell64
Saskatchewan, Canada
2013 Explorer Sport
^^ The Sport have the Hankook Optimo h426 I believe as well.
peterk9
Staff member
Moderator
Callsign
VE3
Not sure what make the optional Sport 265/45ZR20 Summer tire is.
Nairb4190
2013 EX Limited 301a Blis
My 02 MDX that I am replacing with a 13 Limited on order is on its second set of Michelin Cross Country OE. I have over 150k miles on the MDX and rotated them every oil change. Realistically they should have been changed 10k ago but not wasting the money with a new truck on the way. Overall EXCELLENT tire that I got over 70k a set.
Shadow71
SW Chicagoland Burbs
2013 Explorer Limited
My 2013 Limited with 20"s came with the Hankook 255/50R20 H426
The Cheat
Houston, Texas
2014 Ford F-150 FX4
JustB_Rad
Milwaukee WI
2011 Explorer XLT
I have the Michelin's. I only drive with them in the summer, as I have a set of Bridgestone Blizzaks mounted on 17" rims to run in the winter. Mine have maybe 20k on them. When I put them on for the summer 2 weeks ago, I noticed that they are starting to crack around both the tread and the bead near the wheel.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Edited.. error in posting.
TennTom
maryville,Tennessee
2011 f150
traded in my 2011 Ex with 65k plus still had not reached the wear bars had 6mm left that is what was measured at the oil change when I ordered the 2015 I ran 40 psi the whole time better fuel mileage less wear the Michelins were great
Toucan
BELIZE
1998 XLT
Over the last two years 35% of our city streets have been concreted. No more asphalt. What sort of mileage can I expect. Or, how will this affect the life/usage of tires?
peterk9
Staff member
Moderator
Callsign
VE3
No concrete highways here that I know of. I'm guessing that concrete may be a bit harder on tire wear than asphalt. Don't know for sure though.
3rdy
2012 XLT base V6
peter, just wondering what is the advantage of rotating the tire front to back rather that the recommended cross. i had replace my tire with Michelin and have it rotate in the dealer n the last service. the technician told me that they usually rotate the tire front to back not cross, but i insist to rotate my tires front crossed as per as manual recommended for FWD.
O Stock Michelin Woes Stock 2011 - 2019 Ford Explorer Discussion 0
T michelin ltx m/s2? Stock 2011 - 2019 Ford Explorer Discussion 6
M 17s with bigger tires on 2016 Sport?? Stock 2011 - 2019 Ford Explorer Discussion 2
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
W New wheels/tires on '17 Sport Stock 2011 - 2019 Ford Explorer Discussion 6
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
C Explorer Eating tires, alignment off in 6 days!! Stock 2011 - 2019 Ford Explorer Discussion 0
S 2014 explorer base model upgrade tires Stock 2011 - 2019 Ford Explorer Discussion 16
S What tire/wheel size are you running for winter tires? Stock 2011 - 2019 Ford Explorer Discussion 7
L All 4 tires brown on inside track, just bought Stock 2011 - 2019 Ford Explorer Discussion 6
B Winter Tires Stock 2011 - 2019 Ford Explorer Discussion 17
X Noisy Tires 26k miles Stock 2011 - 2019 Ford Explorer Discussion 25
B Looking for to find info on tires for my 2014 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 3
S What All Season Tires are you Using? Stock 2011 - 2019 Ford Explorer Discussion 15
S Bigger tires more or less air? Stock 2011 - 2019 Ford Explorer Discussion 6
E My winter tires are on Stock 2011 - 2019 Ford Explorer Discussion 5
B Lifted 2014 explore sport eating tires Stock 2011 - 2019 Ford Explorer Discussion 20
F Which OEM tires come on Explorers? Stock 2011 - 2019 Ford Explorer Discussion 28
P Tires! Stock 2011 - 2019 Ford Explorer Discussion 1
W Front end noise...Tires? Bearings? ?? Stock 2011 - 2019 Ford Explorer Discussion 20
R New Winter Tires Diameter Change Stock 2011 - 2019 Ford Explorer Discussion 38
B Review: Continental ExtremeContact DWS 06 tires Stock 2011 - 2019 Ford Explorer Discussion 9
1 Need new tires, just bought Interceptor wheel set Stock 2011 - 2019 Ford Explorer Discussion 1
P OEM Tires Lack of Road Hazard Stock 2011 - 2019 Ford Explorer Discussion 14
M 2016 Sport tires Stock 2011 - 2019 Ford Explorer Discussion 23
S Need some advice with rim and tires Stock 2011 - 2019 Ford Explorer Discussion 1
T Recommend a good set of off road/beach tires Stock 2011 - 2019 Ford Explorer Discussion 25
P New tires... PIU specific question Stock 2011 - 2019 Ford Explorer Discussion 7
K Please recommend all weather tires! Stock 2011 - 2019 Ford Explorer Discussion 33
C 2013 Explorer Sport - just got new tires Stock 2011 - 2019 Ford Explorer Discussion 4
H All Terrain / Off Road Tires Stock 2011 - 2019 Ford Explorer Discussion 62
S Tires and daylight running lights Stock 2011 - 2019 Ford Explorer Discussion 4
H Any interest in purchasing single OEM Sport tires for full size spare? Stock 2011 - 2019 Ford Explorer Discussion 4
N Wider tires Stock 2011 - 2019 Ford Explorer Discussion 12
T Mods, might it be worthwhile to start a dedicated "Explorer Tires" thread or sticky? Stock 2011 - 2019 Ford Explorer Discussion 6
T Nitto Crosstek Tires for 2013 EX LTD 4WD Stock 2011 - 2019 Ford Explorer Discussion 6
O How would you rate tires on XLT Stock 2011 - 2019 Ford Explorer Discussion 5
G Time for tires Stock 2011 - 2019 Ford Explorer Discussion 678
T Summer tires vs. all seasons? Stock 2011 - 2019 Ford Explorer Discussion 5
S Do I have dry rot on my '11 tires already? Stock 2011 - 2019 Ford Explorer Discussion 31
G Tires - 2013 Sport Stock 2011 - 2019 Ford Explorer Discussion 17
F Rotating Tires Stock 2011 - 2019 Ford Explorer Discussion 21
T Aftermarket wheels/tires... Stock 2011 - 2019 Ford Explorer Discussion 19
J Dealer Keeps Pumping My Tires to 40 psi.... Stock 2011 - 2019 Ford Explorer Discussion 5
M What tires are they shipping on the 2013 XLT 4wd? Stock 2011 - 2019 Ford Explorer Discussion 22
T 2012 xlt and snow Chains vs winter tires Stock 2011 - 2019 Ford Explorer Discussion 20
A 100% gasoline, amsoil full synthetic, and nitrogen filled tires. What is best? Stock 2011 - 2019 Ford Explorer Discussion 16
X Tires Stock 2011 - 2019 Ford Explorer Discussion 26
B Tires Stock 2011 - 2019 Ford Explorer Discussion 4
N Wide tires Stock 2011 - 2019 Ford Explorer Discussion 0
Similar threads
