Mileage to do timing chain, guides, and tensioners? 4.6l
Harley McIntyre
Lake Geneva, WI
2006 Explorer EB 4.6l
Just rolled over 191k on my 06 v8. At this point I'm just worried about my timing components as I know they tend to start failing around this mileage, as far as I can tell, there's no tick yet on cold start but since I have a manifold leak it's so loud that I'm not even sure id be able to hear the timing tick. So if it's not there yet, how much longer should I have until it appears? I've had this ex since April and have done Mobil 1 high mileage every 5k and have put about 12k on my truck, not sure about previous maintenance.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
175-200k is the range they should be changed. I've taken apart some well taken care of 4.6s and they haven't worn to the metal tensioner even at 200k. I've also taken one apart that wore through the timing cover at 64k. That one had probably only had 1 oil change since it was new and only topped off in between, it was scuzzy.
I'd get the exhaust leak straight first and as long as that goes smoothly continue to the timing chains.
Harley McIntyre
Lake Geneva, WI
Okay, hopefully it can last until I have the money and time to do it, the whole timing kit is about $500 and to do the exhaust will probably run me another 2-300 so I've just got my fingers crossed right now
ThunderbirdSport
Location
Thunderbird Heights
Missouri
2006 Eddie Bauer V8
How hard is it to do timing chain(s) on a 3v?
I mean...I put together the 5.0 for my Mustang, but those are easy (to me) to crack open and stick back together.
No experience with a 4.6, let alone the 3v, other than water pump, coils, and intake removal. (that shit was super easy though. more work to do that same stuff on a 5.0) LOL
Explorer_PL
Rockland County, NY
06EB V8
I did the timing on my 06 and it took about 6 - 7 hrs. Not complicated but time consuming. You need to mark what bolt goes to what hole in the timing cover, there are 3 or 4 types of them: studs, bolts, ...
Remember to have a gasket maker ready for where the valve covers meet the timing cover and the oil pan.
I used motorcraft parts and with the phasers it came out to around 700 buying online. Don't buy aftermarket parts for this job.
Everything is marked so you can not mistime it.
I had some pictures in one of my posts but photobucket took it down from what i see.
ThunderbirdSport
Location
Thunderbird Heights
Missouri
2006 Eddie Bauer V8
Mine isn't making any noise save for the typical exhaust leak, but still...it's at 180K and I don't know if it's been done yet. From what I've found so far, it's been decently maintained though, so who know.
I'll probably get the set at tax time and dig into it, along with hubs and bearings. Rather want to do the upgraded brakes too. We'll see how THAT plays out lol.
Thanks for the words. When it comes to tools...i have more than the average shadetree guy lol.
Trainmaster
Rockaway Beach NY
2010 Limited
Relax. You've been on line too much. Most never fail. I had one with 260,000 miles. The timing chain was fine, along with the guides and phasers. You'll know when it's failing. Find a hobby.
07EddyB
Bowling Green, KY
2007 Ford Explorer 4.6 V8
I can't tell you how many times I've figured that I had the cam phaser / guides / tensioner issue. It was always something else. As Trainmaster says - I've been on line too much and read too much.
I'm slowly developing a more relaxed attitude when the slightest noise pops up.
ThunderbirdSport
Location
Thunderbird Heights
Missouri
2006 Eddie Bauer V8
Smartass, the point is to not have failure...lots of info out there that indicates around 180K with good maintenance is about the time when replacement is needed.
Good on you to have one go 250K+ without incident. I've got a 5.0 F150 with 400K on it...all that's been done was a timing set, oil pump, and an IAC...
Trainmaster
Rockaway Beach NY
2010 Limited
...“A coward dies a thousand times before his death, but the valiant taste of death but once."
If it isn't broke, put your time to better use. Timing chain replacement isn't preventative maintenance. Most motors never need the work for the life of the car. As I said, find a hobby.
ifixcopcars
Mead
2010 Adrenalin 4.6
I agree with Trainmaster. I maintain a fleet of cop cars, still have about 65 Crown Vics in regular patrol, some pushing 300K miles. I can promise you these 4.6 engines have seen more abuse than any civilian version ever dreamed of and only 1 has been apart for timing components (and that's because the driver ran a stop sign post thru the radiator and on into the timing cover).
About 16 years ago I was visited by the Ford boys from Dearborn, they wanted to look at the undersides of our CV's for rust (we don't have that problem where we are located), but we got into the timing component conversation and I was told they had tested these engines to 750K miles using 5w-20 semi synthetic oil, changed at 6K miles and had no failures and no appreciable wear. They emphasized the viscosity was the key to longevity.
Eric Tang
Lititz, PA
1995 Explorer XLT
If it ain't broke, don't mess with it. You take a chance of causing a whole lot of other problems.
94Eddie
2010 Mountaineer Premier
On the flip side, the reason many, many 4.0L Explorers/Mountaineers reach the end of their lives is from timing chain failure due to repair costs exceeding the vehicle's value. A pre-oiler is one measure worth considering to extend the lifespan of a 4.0L engine.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Yes this applies to the 2v engine. You won't see a 3v hit 300k without a set of cams and followers.
D Around What Mileage do the Timing Chains Give Up? Stock 2006 -2010 Explorers 8
F Explorer 2009 mileage Stock 2006 -2010 Explorers 0
0 Age versus mileage Stock 2006 -2010 Explorers 7
H 4.6l high mileage reliability and maintenance? Stock 2006 -2010 Explorers 6
L At what mileage did your fuel pump die Stock 2006 -2010 Explorers 13
digifoss 4th Gen gas mileage question V6-4x4 vs V6-2WD Stock 2006 -2010 Explorers 5
M Talk about a low mileage Explorer Stock 2006 -2010 Explorers 6
C Bad gas mileage and lots of small problems Stock 2006 -2010 Explorers 15
S Gas mileage and general maintenance -- what else should I do...? Stock 2006 -2010 Explorers 4
Z 4L hi-mileage synthetic... opinions? Stock 2006 -2010 Explorers 27
N Looking for thoughts on sudden drop in gas mileage Stock 2006 -2010 Explorers 10
N Gas Mileage Question Stock 2006 -2010 Explorers 28
G mileage: reliability and major repairs ? Stock 2006 -2010 Explorers 10
N Gas leak ? Gas mileage doesn't add up!!! Stock 2006 -2010 Explorers 7
N Bad gas mileage... looking for a fix? Stock 2006 -2010 Explorers 22
S High mileage maintenance advice for 06 V8? Stock 2006 -2010 Explorers 7
E 2010 throwing P0443, Gas mileage improvement devices Stock 2006 -2010 Explorers 7
G At what mileage should the trans filter and fluid be replaced? Stock 2006 -2010 Explorers 1
N ford explorer2009 fuel mileage reducing Stock 2006 -2010 Explorers 4
B Active mechanism for Average Mileage Calculation? Stock 2006 -2010 Explorers 0
F Highest mileage 2006-10 Explorer/Mountaineer Stock 2006 -2010 Explorers 66
I High mileage- how long will this generation go for? Stock 2006 -2010 Explorers 27
L Computer estimated gas mileage off. Stock 2006 -2010 Explorers 9
JMan689 Buying higher mileage 4th gens Stock 2006 -2010 Explorers 5
N 2007 Eddie Bauer v6 gas mileage? Stock 2006 -2010 Explorers 21
O 2006 Explorer V8 4WD Gas Mileage Woes Stock 2006 -2010 Explorers 19
C Loud bang, now lower gas mileage !!! Stock 2006 -2010 Explorers 7
F What maintenance at 80k miles will raise gas mileage? Stock 2006 -2010 Explorers 6
S Gas Mileage Seems Low Stock 2006 -2010 Explorers 7
F Actual gas mileage of ford explorers? Stock 2006 -2010 Explorers 7
B Poor Gas Mileage and Rough Sounding Stock 2006 -2010 Explorers 8
9 Disappointing Gas Mileage When Towing Stock 2006 -2010 Explorers 36
E Highest mileage on 06 and up Explorers (over 100K miles) Stock 2006 -2010 Explorers 27
1 Best RPM's for Gas Mileage Stock 2006 -2010 Explorers 11
S New oil/air/fuel filter - mileage drops Stock 2006 -2010 Explorers 2
W 2006 xlt with 87k mileage...should we buy it? Stock 2006 -2010 Explorers 7
D Mileage and Power Improvements Stock 2006 -2010 Explorers 13
K How bad is your mileage? Stock 2006 -2010 Explorers 30
C fuel mileage Stock 2006 -2010 Explorers 1
E Mileage difference between V6 and V8 Stock 2006 -2010 Explorers 10
J rear timing chain Stock 2006 -2010 Explorers 1
D Do these models have the timing chain issues Stock 2006 -2010 Explorers 14
M And we thought the 4.0 timing chains were silly Stock 2006 -2010 Explorers 10
R 2006 V8 Eddie Bauer, 300k miles. Timing chain, guides, tensioners Stock 2006 -2010 Explorers 3
M 06 timing chain rattle Stock 2006 -2010 Explorers 5
E Will changing my timing chain tensioners do more bad than good? Stock 2006 -2010 Explorers 23
H Have timing done by a mechanic? Or just replace the whole engine? 4.6l Stock 2006 -2010 Explorers 4
doug625 Looking to buy a 4th gen. Do any 4.0s exist without the timing chain rattle? Stock 2006 -2010 Explorers 22
E Looking for a shop in NY/NJ/PA able to rebuild timing on 4.0 Stock 2006 -2010 Explorers 5
J 2007 4.6 timing chain quote$ i got Stock 2006 -2010 Explorers 20
Similar threads
