Mini Spool for 8.8 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Mini Spool for 8.8
OREXPLORER
Twin lake, Mi
'92 XLT
I am thinking of putting a mini-spool in my 8.8 because I can't afford running a locker due to tight finances. I was wondering the pros and cons of this set up. I am currently running 33" Mickey Thompsons and plan to switch to 4.56 gears when I put in the spool. I was also told I would have to get a c clip eliminator kit which runs about 200$! Is this true?? (in which case I might as well just get a locker). thanks for the input
Hotweels
Calgary,AB
'92 EB
ya that about sum's it up
spool or mini spool = c-clip elim's
locker = cost of c-clip and spool/mini spool
not sure if they make a detroit tru-trac for the 8.8" with c-clip's but that would be my suggestion
lock-rites are cheep tho.........
JTX
New Mexico
94 xlt
Jegs has a mini spool for the 8.8 that doesnt need the c-clip elimination.
FireZapper
Columbia Pa.
93 Sport
My Alburn didn't need the elimator. Just grind the clip flat to fit in the slots.
you do not need to wait to change gears for a mini spool.
Pro.. traction!
Cons.. tire scrubbing on tight (3 point tight) turns.
CodePoet
Indianapolis, Indiana
1993 XLT
If the budget is tight and your ready to run a spool...why not weld it? All it costs is the price of the rods :D
Hotweels
Calgary,AB
'92 EB
cool... last time i asked about a spool or mini spool for the X i wuz told i needed the elim's
next problem will be keepin the carrier from bustin in half....
Hotweels
Calgary,AB
'92 EB
a good idea but i have tried this with 2 8.8" carriers and they both broke shortly after leaving the parking lot... one was welded by a 8yr journeyman welder the other by a backyard mechanic who has welded up alot of 9"s for hotrodders and wheelers.... maybe i just have bad luck?
allout
Nanaimo BC Canada
93 Sport
A full spool will need the c clip eliminator. The mini spools fit inside the carrier just like a lunchbox locker and the c clips are still used.
Creager
Charlotte, NC
'92 Sport 4x4
mini spools are like $150
aussie lockers are $229
TrueTrac (new) is $400
Arnie897
y=mx+b
Battle Creek, MI
06 Dodge Powerwagon
I'm running welded with 4.56's. No complaints. :D
