pbnj22
- June 30, 2011
- duluth minnesnowta
- 00 xlt 5. v8 awd
00 explorer 5.0
I got a mis fire in cyl 7... replaced plugs, plug wires, swapped coil packs and mis fire did not move, changed fuel filter, tested fuel pressure and it was good
ran sea foam in crank case, gas tank and vacuum hose... still no luck with my mis fire.. so what is next?
Anything else i can try before i do injectors? Should i test them by checking ohms and then putting 5 volts to each one? should i replace all of them or just the suspected bad ones? anyone have advice or a write up for how to get to the injectors before i rip things apart? thanks in advance
