nitrolouie2142
- August 1, 2009
- Sunapee, NH
- 05 Eddie Bauer
Got an 05 Eddie with the 4.6, 177,000. started misfiring the other day. Borrowed a friends scanner and found #8 cyl. was the culprit. Picked up plugs cause who knows when it was last tuned. When I pulled the #8 coil off I found water in the plug well, so that explains the misfire. But has anyone else had this issue. It isn't antifreeze just water, haven't lost any coolant since I flushed the system last July.On a side note who was the designer that was on drugs when they decided that would be a good place for a fuel filter :frustrate :frustrate that almost took longer than the plugs. Any ideas on the H2o issue would be appreciated.
