JustinY
- April 1, 2013
- Minot, ND
- 92 Ford Explorer
I have a 92 explorer, 5 speed, that will randomly have varing degrees of missfire on startup. 50% of the time its missing on maybe 1 or 2 cylinders, but sometimes it wont run unless I stay on the throttle and is only going on maybe 2 or 3. After driving for about 30sec-1min, it runs fine. I did notice an odd gurgling sound coming from the fuel tank when it's at it's worst. I checked the fuel pressure while it was running fine and according to the chilton manual it was 3psi low of the range with and without the vacuum line on the regulator. I also checked the plugs and they all looked fine.
Is the slight low fuel pressure the cause? Considering there is a pressure range, and it is below that, I figure even 3 psi would cause issues. If so, what could be causing it? I assumed fuel pumps just went out, not lost pressure. I also dont know when the filter was last changed.
The problem is slowly getting worse over time, but seems to be the very worst after sitting hot for 15-30 min or so. Also the hotter the weather, the more often it happens too.
Thanks for any help.
