Missfiring + Underpowered | Ford Explorer Forums - Serious Explorations
kid101skater
Seattle, Washington
'94 Limited
Have a missfire as well as very underpowered..
Replaced Camshaft positioning sensor, Mass Air flow sensor, Fuel Pump, Spark plugs and wires, Fuel Filter, Ignition Coil.
I have no check engine light.. But its a *****..
And exaust is sputtering.
Have you checked your injectors? I had a similar problem a while back, and the injectors being clogged was part of the problem! Also check your throttle position sensor and your EGR system.
Well the TPS would set a code, its electrical, And no signs of a vacume leak, egr seems fine... i think tomorrow were taking off the header and redoing the valves
Not necessarily. It's easy to check, as it is basically just a potentiometer, and the computer wouldn't know if it was just reading wrong. Also, seriously consider the injectors before you tear into the heads.
Well i also ran cleaner through it... Smoked like a Bi**h and yeah... i just need this working. Any other suggestions?
