Missing fire i think
mesa 33
Clearwater,Florida
'98 xlt
Have a 98 explorer with the ohv, in the winter it started to stumble or say so like missing maybe but after it would warm up it would be just fine. Then a couple days ago it started again but would fix itself, but now its constant and would repair itself lol. I changed the spark plugs tonight and still nothing but it does idle better. Not sure what to check next, theres no check engine light. thanks in advance for the help
nick
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Xplorer82
OH.
'97 XLT... '98 Eddie...
nick
there are a few things that come to my mind right now.
-clean the MAF sensor w/MAF cleaner
-test the resistance of the coil pack to determine if its bad.
-check the plug wires for any cracks, when were they changed last by the way?
-when is the last time the fuel filter was changed?
-check for vacuum leaks as well.
mesa 33
Clearwater,Florida
'98 xlt
Alrite thanks.
I changed the spark plugs becuase some were cracked and missing rubber around them, cleaned the MAF sensor and put in a new fuel filter. Once i started it the check engine light came on and is overheating. Code that came up was PO102 which says
intake air leak-duct tube loose or damaged
open or short circuit condition
poor electrical connection
TP signal error
Faulty MAF/VAF sensor
i dont know what a TP was and searched TP but nothing came up. I know there a black tube thats connected to the side of the black intake hose thing but its been like that for awhile and wouldnt think that would do much. It still stumbles i guesse you could call it and you cant floor it, but in neutural you can rev it.
mesa 33
Clearwater,Florida
'98 xlt
ttt
mesa 33
Clearwater,Florida
'98 xlt
ok so i just now got a new MAF sensor got home diconnected negitive and installed new one reconnected negitive and still the same problem no fix yet. what to do now? maybe try VAF sensor?
T Suddenly missing Under the Hood 3
H Missing Under the Hood 4
D Bolts missing Under the Hood 10
A Please help identify missing hose/troubleshoot Under the Hood 4
C 1993 ranger 2.3 when engine gets hot it seems like it's missing Under the Hood 1
S 4.0 with 4speed Auto, no mods, missing while under load Under the Hood 0
J Engine missing right after oil change Under the Hood 1
1 4.0l sohc missing water pump bolts and dipstick Under the Hood 0
A Missing hood rod? (Thing that holds the hood up) Under the Hood 5
R Cylinders missing Under the Hood 2
F 1997 explorer 5.0 V8 missing intake vacuum hose errati idle hissing sound code P0171 Under the Hood 11
J Missing at high speed? Under the Hood 1
R missing oil dipstick Under the Hood 3
J Am I missing a piece? Under the Hood 21
9 missing vacuum line??? Under the Hood 0
G Missing Part, Please help! Under the Hood 18
M Missing vacumm hose for intake manifold Under the Hood 1
I Fuel pump problems, is there something I am missing? Under the Hood 11
A 98 Explorer XLT 4.0 missing problem. Please help! Under the Hood 3
S Missing sensor Under the Hood 0
M 302 missing Under the Hood 3
Willard Hot missing problem Under the Hood 19
D Engine missing on start-up Under the Hood 1
S Strange missing problem Please help!! Under the Hood 1
I Engine seems to be missing after stopping.. Under the Hood 1
J Starts missing at 3200 RPM Under the Hood 2
S Missing when accelerating Under the Hood 0
9 Missing badly and no power Under the Hood 3
D missing bolt, where can i get one Under the Hood 10
E missing=bad coil? Under the Hood 3
D Need Help - Missing on Cylinders 2,3, and 5 Under the Hood 5
L 1997 Explorer surging/Missing Under the Hood 3
D The Mystery missing coolant and Tranny O/D - shift problem. Under the Hood 5
M Missing Keypad Code 2003 Explorer Under the Hood 2
T Help, power loss, missing! Under the Hood 46
L Missing at ~30MPH Under the Hood 0
S Intermitten Missing Problem Under the Hood 15
S Missing Engine Under the Hood 8
S V8 Missing and bogging down Under the Hood 1
M 94 Limited - Missing Badly...HELP Under the Hood 7
H 92 EB missing (new motor) Under the Hood 4
D Missing Fluid Under the Hood 2
T UPDATE: Missing/bucking -- something causing plug wear Under the Hood 6
V Help Diagnose my intermittant Missing Problem Under the Hood 86
B '91 missing , not plugs or wires ??? Under the Hood 3
B Missing vacuum line on 99 SOHC Under the Hood 1
W Engine Missing Under the Hood 12
M Need help with Missing Engine Under the Hood 6
B Vacuum line missing on 4.0L, engine pics needed! Under the Hood 2
M Brake job - missing thrust washers? Under the Hood 0
Similar threads
