MoabB2
- March 21, 2006
- South Jordan, Utah
- 89 Bronco II (97 Mercury)
A few updates as of 1/23/2020 shown below:
When it was new: Version 1.0
Brand new in 1989 sold in Fort Worth, Texas.
2.9L V6, auto trans, BW1350 manual t-case, manual locking hubs, power windows, doors, AC, 60/40 split bench, Dana 28 TTB, 7.5 rear, 3.73 ratio.
I bought the truck in April, 2004 from the second owner. I flew to Fort Worth, handed over the money, and drove it back to Salt Lake City. It had a few modifications at that time. I was told it had approx 150k miles, but I suspect it was 250k.
Then it had: Version 2.0
-Rebuilt 2.9L V6
-Rebuilt A4LD automatic
-6" Skyjacker coils and shocks, drop brackets and pitman arm, lift blocks
-31" BFG All Terrains
-Flowmaster exhaust
-Sweet pillar mount spotlight
-Warn hubs
-Panasonic CD Head Unit
I used the Bronco to commute to college and to work for about a year. I put a lot of miles on it and wheeled it a lot. I towed 4 wheelers often and took the family camping in it. I made a few minor upgrades.
Once I got through college, I figured I would reward myself and start the V8 swap. Little did I know what I was getting myself into. I figured a 5.0 was a 5.0.... I located a wrecked '97 Mercury Mountaineer and got a great deal on the drivetrain, wiring, and PCM. 3 years later we are still working out the bugs related to the swap, but overall it has been a huge success and has worked VERY well. OBDII proved to be a huge challenge. I then upgraded to 33" Cooper SSR's and 15x10 wheels.
I never was too fond of the faded brown paint. And, I wanted to take my truck to another level. I found Ratstang Restoration and Richard was able to help do that. A Frame-off body restoration took about 10 months. Every nut and bolt was removed.
Restoration: Version 3.0
Restoration Thread in signature
The bronco was then the Cover Bronco/Featured Ride for Bronco Driver magazine. It was the first Bronco II to ever grace the cover.
Magazine Thread in signature
BroncoDriver.com
After wheeling for a few years I started to realize what the bronco needed to be able to keep up on more hardcore trails. It had done fine the open diffs and weak axles for years, but I wanted more. SAS time!
Say bye-bye to everything below the frame: Version 4.0
SAS Thread in signature.
Chop Chop: Version 5.0
It's a never ending quest to be bigger, badder, lighter and better. As the bronco has slowly relinquished daily driver duties, it has transformed over time into more and more of a trail rig. Version 5.0 includes:
-Custom built, frame mounted, internal family roll cage.
-We gutted the entire interior, cut through the floor and tied into the custom rock sliders.
-Redesigned custom front and rear bumpers, with angled rear tire carrier.
-Goal was to gain better approach and departure angles and clear 37" tires.
-Removed front valance, mounted superwinch behind the grill / inside the frame rails.
-Front bumper tabbed for light bar, fog lights, and dual D-Loop mounts.
-Rear bumper with 2" receiver, centered/angled tire mount to accept 37" tire that swings either direction, integrated hi-lift mount, integrated removable mud flaps.
-Fenders cut (again) to accommodate 37" tires
-Custom metal 'flat fender' flares
-37x12.50x17 Kevlar MTR's, mounted on 17" beadlocks with custom red painted rings.
-Removed front inner fenders. She can finally BREATH!
-Custom frame mounted rock sliders with kick-out side steps
-Removed the rear side glass windows. Installed removable snap-in vinyl windows. By far the best modification I've made! (Step on 37" tire, enter back seat through window opening = AMAZING!)
-New headliner
-Dynamat sound deadening throughout entire cabin.
-New to me, junkyard 60/40 split bench from '90 ranger.
-JVC headunit with bluetooth, aux/usb front ports, hands-free phone integration, SiriusXM satellite radio with antenna mounted above the rear hatch.
-New front speakers
Depending on the weather the truck still occasionally gets me to work and runs errands. daily driver for about 6 months of the year. Future plans include updated CAI and routine maintenance
A current list of the ever changing mods: (I'll try to keep this up to date)
BODY:
-Frame Off Restoration, show quality body and two-tone paint.
-Buckingham Blue Pearl Metallic and Chawton White.(Land Rover)
-Custom tubed front clip and radiator support.
-James Duff Polyeurathane Body Mounts.
-Custom metal 'Flat Fender' flares, significant trimming.
-Deleted inner fenders
-Custom grill.
-Custom vinyl snap-in/out rear windows
-Deleted front valance under grill
DRIVETRAIN:
-5.0L V8, GT-40p Heads. (donor, 1997 Mercury Mountaineer. 65k)
-4r70w, AOD-EW transmission.
-OBD-II PCM and Diagnostic Port.
-Custom dyno-tune via xCal3: 215 RWHP / 273 RWTQ
-Custom dual exhaust with dual Flowmaster 40 series, rear exit.
-Torque Monster Headers.
-Aluminum Radiator
-B&M Transmission Supercooler with Temp Guage.
-Manual BW1354 Transfer Case, 34.4:1 Crawl Ratio
-Solid Axle Swap: Early Bronco Dana 44
----Fully rebuilt
----Disc Brakes
----Yukon chromoly shafts, 4.88 gears, Superjoints
----Warn Premium manual hubs.
----ARB locker
----Cage Offroad trac-bar mount
-Rear end swap: Early Bronco big bearing 9"
----Fully rebuilt
----Drum Brakes
----Yukon 31-spline shafts, 4.88 gears
----ARB locker
-Custom heavy duty driveshafts.
-Custom brake lines, front and rear.
-Dual sump oil pan
-Optima yellow top battery
SUSPENSION:
-All new suspension
----3.5" Cage Offroad Early Bronco front coil springs
----Cage Offroad Early Bronco extended radius arms & mounts.
----4 Bilstein shocks
----James Duff Zinc Plated Coil Buckets
----Cage Offroad shock mounts
----Skyjacker Bronco II 6" Leaf Springs
----96" wheelbase
WHEELS AND TIRES
-37x12.50x17 Goodyear Kevlar MTRs with full size spare
-5 17x10 5x5.5 Allied Rock-a-Thon Beadlocks with custom red painted rings
BODY PROTECTION/ARMOR:
-Custom front and rear bumpers with full size spare tire/Hi-lift Jack swing out.
-Custom frame mounted rock sliders with kick-out steps.
-Custom internal frame mounted family roll cage.
OTHER:
-30" front LED light bar, 2 front LED pods
-JVC Head Unit with integrated Bluetooth, USB/AUX, handsfree calling and SiriusXM
-Midland CB radio with antenna.
-Yakima Loadwarrior basket with axe/shovel brackets.
-Rear bumper mounted Hi-Lift Jack
-Custom FX4 Decals
-5.0 badges
-Rebuilt 2.9L V6
-Flowmaster exhaust
-Warn hubs
BroncoDriver.com
-New headliner
-New front speakers
BODY:
-Custom grill.
DRIVETRAIN:
-Aluminum Radiator
----Fully rebuilt
----Disc Brakes
----ARB locker
----Fully rebuilt
----Drum Brakes
----ARB locker
-Dual sump oil pan
SUSPENSION:
-All new suspension
----96" wheelbase
WHEELS AND TIRES
OTHER:
-Custom FX4 Decals
-5.0 badges
