So what is the verdict Zab- Do you suggest shaving and grinding the combs flush? Do they really do anything or can they be eliminated.
Well, just for the heck of it I went ahead and pulled my TB off this weekend and did some reworking. I started by cleaning it up really well, removed the butterfly and half shafted the throttle shaft. Filed and flushed the screws, polished the shaft and even smoothed the edges of the butterfly. Move the TPS as well to get as close to .99v as I could.
Had the batt. cable off the whole time so the EEC was good and clear. First thing I noticed was the idle was up from ~500rpm in park to around 900rpm now and the idle was noticeably smoother (always new it was idleing too low) I did also notice a slight bit more throttle response and SOTP feel when coming down on it to pass. But overall it took me an hour to do and wasn't hard at all.
Would I say its worth it?----------- if you do it yourself, yea why not.
But pay $200-300 for it, NOPE.
Well let's see some pictures of your handywork.
Hold on now. I can't speak for everyone but I was under the impression that Todd was just milling down the shaft and grinding screws. I've since talked with Todd and I've learned that that wasn't the case. So if boring is involved then yes, the price might be close.
You might want to go and read the very first post you typed up. You said shaft and screws.
Upon consulting with Todd several times, I decided to have him also enlarge the throttle body bore before the butterfly valve ( which was 65mm ) to as close to 70mm, like the rest of the throttle body, as possible in addition to the screw and shaft modification. Why Ford made that throttle body that way is a mystery to me.
Test results ….
The first 250 mile leg of the test was with the new throttle body. The average speed was 69.3 MPH. Gas mileage was 32.6 MPG.
The second 250 mile leg of the test was with the old ( stock ) throttle body. Average speed was 68.9 MPH. Gas mileage was 31.2 MPG.
The net increase in gas mileage is 1.4 MPG. The difference in throttle response is easily noted.
Jakee, you're spinning one wheel. You only have to overcome the force of friction for one tire. People with LSD have to overcome twice the frictional force for two tires, so theoretically, they will need twice the power. This means your truck could have half the power of mine or Todd's and you'd still be able to theoretically break the tire loose.
Sorry Jakee, one wheel is dog mess in my book. You need to be able to inihilate both skins at once. Sitting still? What type/size of tires are you running?
Todd, 290lb of Torque at the wheels is damn good better than many years of GT Mustangs.
