The install ....
The removal and replacement of the throttle body was a straightforward less than 10 minute job ( see
http://www.explorerforum.com/forums/showthread.php?t=139454&highlight=throttle+body ). Prior to removal the negative battery cable is disconnected and reconnected after the install.
Prior to the new throttle body install, I conducted several WOT 0 to 80 MPH runs so I would have a comparison to the same with the new throttle body.
Initial impressions on a road test and the 0 to 80 MPH runs were positive; I undeniably felt a difference in throttle response and acceleration at higher RPMs. There were no issues with the cruse control function.
The throttle response alone is worth doing the mod.
I shall be making a 1500 mile road trip ( to the Atlanta area ) this Friday; gas mileage will be evaluated. I plan to swap the modded throttle body with the stock one on one leg of the trip for a direct comparison.
Mileage data will be reported after the trip.
A jaunt to the dyno is also in the works; stay tuned.
NOTE: the pictures of the before and after of the shaft and screws were borrowed from the Sport Trac website. They are of a stock throttle body and are better quality than the ones I took.
