alk8778
- February 10, 2005
- Rochester Hills, Michigan
- 2000 Mountaineer
Well I need some input/ideas from some other people as I'm starting to run out of them... My father in law is a trans tech at Ford and with his computer and help I should be able to do anything... I just need ideas of places to start...
Background -- 2001 Mountaineer 5.0. Explorer Express Eaton M90 ~8lbs . Blue Ford 39lb injectors. Torque Monster Headers, Walbro 255lph in tank pump. Tuning by Alternative Auto.
Engine seems to be running rough. I have had this issue for a couple of years and have either just driven through it or not had the motivation to fix it. Last year only put a couple hundred miles on it because of the issues. Last fall I pulled the motor with intentions of putting it into a Ranger, however that plan got sidetracked and it went back in the mountaineer for this summer. When it went back in I put a brand new alternator on it. Found a ground wire on the main harness that wasn't securely fastened to the block last year. It got all new spark plugs (as i do this once a year). New (Livewires) spark plug wires, heat shields around the plugs and "screamin demon" coil packs.
In the past it would throw a code for the cam position sensor. I replaced the entire synchronizer once, replaced the sensor twice. Had my father in law check the power balance and everything seems to be in check. Ran a jumper wire on that circuit from the sensor directly to the ECM and after all that... it will still continuously throw a code for the cam pos sensor.
Ran a compression check and all cylinders are within 5psi of eachother, all over 140. Pulled valve covers and inspected, everything visually ok. Inspected the entire wiring harness checking continuity between all connectors and ecm connector and it all checked out.
Just got it all back together last night and again it is running rough... very primative diagnosis leads me to believe the #4 cylinder (closest to firewall on passanger side) is not running as hot as the rest of the cylinders... whether that be from fuel or spark, i do not know (motor was warmed up and water squirted onto each tube from the header. #4 cylinders header was significantly cooler than the rest) No CEL as of now, only drove it a few miles.
I've been chasing the problem for a few years and never seem to get it dealt with. Any input, places to look, things to test would be GREATLY appreciated. I will have the assistance of my father in law this weekend so any head starts or ... anything would be awesome.
