dpliner
- April 15, 2009
- Richland Center, WI
- 2003 XLT
This is my list I want to do to my '03 XLT.
I already have:
Westin front brush guard and lights on that.
Westin brake light guards
K&N intake kit
If anyone has seen any of these cheaper let me know. Remember these prices are new prices that I randomly found on searches.
2003 Ford Explorer XLT Modifications to do
• 285/70/17 BFGoodrich All-Terrain T/A® KO tires ($259.00/each or set of 5(with spare)/$1295.00)
• 17”x9” Dick Cepek DC-2 Rims ($136.99/each x 5 = $684.95)
• BTF Lift Spacers 2.25”Front, 1.75”Rear
• BTF Uniball Upper Control Arms
• 3” Body Lift ($195.37)
• Front Wheel Bearing and Hub Assembly (Timken SP470200 - $183.95/each – 2 required)
• Read Wheel Bearing and Hub Assembly (Timken HA590259K - $152.95/each – 2 required)
• 1.5” Wheel Spacers ($47.50/each)
• Gibson Cat-Back Exhaust ($343.71)
• Gibson Exhaust Performance Header GP219S-C ($562.50)
• Accel Coil Pack ($83.95)
• New Spark Plug Wires ($89.95)
• New E3 Spark Plugs ($5.99/each – 6 required)
• SCT Touch Screen Xtreme Ford Programmer (SCT Part Number: 8900) ($859.00)
• Hood Scoop ($179.95)
• New Serpentine Belt ($33.99)
• Change Front Differential Fluid (Royal Purple HPM Gear Oil 80W90) ($21.99/qt. x 2qt.s = $43.98)
• Change Rear Differential Fluid (Royal Purple Max-Gear Synthetic Gear Oil 75W140) ($19.22/qt. x 2qt.s = $38.44)
• Change Transmission Fluid (Royal Purple Max ATF) ($13.56/qt. x 13qt.s = $176.28)
• Change Transmission Filter ($13.99)
• Change Transfer Case Fluid (Royal Purple Max ATF) ($13..56/qt/ x 2qt.s = $27.12)
• Engine Oil (Royal Purple 5w30) ($8.68/qt. x 6 = $52.08)
• Oil Filter (Royal Purple) ($12.69)
• Royal Purple Ice Radiator Super Coolant Additive ($14.89)
• Power Steering Fluid (Royal Purple Max ATF) ($13.56)
• Power Slot Brake Rotor Front Right ($118.00)
• Power Slot Brake Rotor Front Left ($118.00)
• Power Slot Brake Rotor Rear Right ($82.00)
• Power Slot Brake Rotor Rear Left ($82.00)
• Hawk Brake Pads Front Set ($89.00)
• Hawk Brake Pads Rear Set ($70.00)
• Yakima MegaWarrior Roof Rack ($369.00)
• Yakima MegaWarrior Stretch Net ($49.00)
• Yakima Spare Tire Carrier for Roof Rack ($89.00)
• Yakima Hi-Lift Jack Carrier for Roof Rack ($89.00)
• Hi-Lift Jack HL485 48" Hi-Lift Red All Cast Jack ($73.99)
• Hi-Lift Jack HK-B Black Handle-Keeper ($11.82)
• Hi-Lift Jack ORB Off-Road Base ($33.79)
• Yukon Gear 4.11 Ford 8.8, part number YG F8.8-411 ($230.52)
• Yukon Gear 4.11 Dana 30, part number YG D30-411 ($230.00)
• Yukon Gear Master Kit, Ford 8.8 31 Spline, part number YK F8.8-IRS-SUV ($221.66)
• Yukon Gear Master Kit, Dana 30 Super (Ford), part number YK D30-SUP-FORD ($229.24)
• Used 3.73 Ring & Pinion Carrier for front and rear differentials
I already have:
K&N intake kit
