Moonroof Drain hoses c/w diagram
Drako99
Edmonton, AB
2013 Explorer XLT
Does anyone know where they drain?
I can trace from the roof, via headliner down the A pillars.... then Not sure where they go from there.
Can I see them from under the Explorer?
LukerDooker
N.E.
2013Limited 301A TuxBlack
Likely not, they prob drain to the A/B pillars behind the trim facia, and that runs
down towards the area between the doors or quarter panels.
The door channels outside the seals, the rear hatch outside the seals, all are drain paths when the doors are closed.
Look on fordparts and prob you can view some diagrams of parts including the tubing, which is likely short.
Lots of water ends up channeled to the doors to drain out.
Not likely any manufacturer runs tubes that far, they all will exit fairly close by.
Thats a lot of skinny tubing that could clog with gunk, ice, pollen and dust, all the gunk in rain water etc...doubt that.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
I actually had one of the Explorer engineers show me the sunroof drain. If you open the rear liftgate on the top right up where the wiring comes out of the body into the liftgate you will see an open tube facing you. Thats it.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
There are FOUR drain locations. The rear gate as described, the two front inner fender wells and down along the driver side rear door.
Ill attached a pic to this post shortly.
Jason
Here is the pic
broken strut
CHIMOMAN VILLE
2013 White Sport
Funny. The rear drain is located exactly where all the leaks are occurring.
Riley
'13 XLT 4WD
Open the sunroof, pour a cup of water down each drain hole and look for the puddles on the ground.
Eticket
Cary, NC
2014 Explorer sport
Jason
Here is the pic
Nice, thank you...
Sdmf
Ma
02 explorer Eddie beauer
I was also looking for them .. thank you !
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
Note that the diagram is for a 5th gen Explorer and they may not be the same in an '02.
S Help Clearing Moonroof Drain Lines on '16 Explorer With Dead Motor Stock 2011 - 2019 Ford Explorer Discussion 26
C Manually close moonroof Stock 2011 - 2019 Ford Explorer Discussion 3
B Moonroof Help Stock 2011 - 2019 Ford Explorer Discussion 1
L moonroof auto close Stock 2011 - 2019 Ford Explorer Discussion 8
S Moonroof shade won't close fully and tilt/slide doesn't work Stock 2011 - 2019 Ford Explorer Discussion 1
J Moonroof opens even more after hitting switch a second time Stock 2011 - 2019 Ford Explorer Discussion 4
S Moonroof Shade Only Closes Over Rear Window Stock 2011 - 2019 Ford Explorer Discussion 2
C Moonroof Motor? Stock 2011 - 2019 Ford Explorer Discussion 1
Q Moonroof doesn’t work Stock 2011 - 2019 Ford Explorer Discussion 13
M 2013 XLT moonroof won't open Stock 2011 - 2019 Ford Explorer Discussion 3
D 2011 Moonroof issues / reprogramming Stock 2011 - 2019 Ford Explorer Discussion 2
F MoonRoof Has Mind of It's Own Stock 2011 - 2019 Ford Explorer Discussion 5
M Moonroof opens by itself Stock 2011 - 2019 Ford Explorer Discussion 29
T Moonroof Shade Breaks Stock 2011 - 2019 Ford Explorer Discussion 6
K 13 Explorer Moonroof closes and then vents automatically. Wont stay shut Stock 2011 - 2019 Ford Explorer Discussion 6
H 2013 Explorer XLT Moonroof Stock 2011 - 2019 Ford Explorer Discussion 3
kaotikgood 16-17 moonroof question Stock 2011 - 2019 Ford Explorer Discussion 6
P Moonroof Shade Flapping Stock 2011 - 2019 Ford Explorer Discussion 18
N Can I have the Moonroof & Sun shade open just a little? Stock 2011 - 2019 Ford Explorer Discussion 2
I Moonroof stopped working Stock 2011 - 2019 Ford Explorer Discussion 2
J Moonroof Weather Stripping chips Stock 2011 - 2019 Ford Explorer Discussion 2
N Squeaky Power Moonroof Shade Stock 2011 - 2019 Ford Explorer Discussion 17
B Moonroof + Cargo Box Stock 2011 - 2019 Ford Explorer Discussion 24
K 2016 Explorer Moonroof Stock 2011 - 2019 Ford Explorer Discussion 14
cwescapexlt4x4 Moonroof not closing at times Stock 2011 - 2019 Ford Explorer Discussion 2
E 2011 Explorer Moonroof Leak Stock 2011 - 2019 Ford Explorer Discussion 2
M Moonroof Issue Stock 2011 - 2019 Ford Explorer Discussion 30
S Moonroof seal Stock 2011 - 2019 Ford Explorer Discussion 0
B Moonroof Will Not Close Stock 2011 - 2019 Ford Explorer Discussion 118
F 2014 Moonroof option Stock 2011 - 2019 Ford Explorer Discussion 3
M Need Help with Moonroof Stock 2011 - 2019 Ford Explorer Discussion 3
M Power to rear view mirror and dual moonroof? Stock 2011 - 2019 Ford Explorer Discussion 0
N Dual panel moonroof question Stock 2011 - 2019 Ford Explorer Discussion 24
D Moonroof and ability to resell Stock 2011 - 2019 Ford Explorer Discussion 25
L Dual moonroof shade question Stock 2011 - 2019 Ford Explorer Discussion 1
B Moonroof Opens Twice Stock 2011 - 2019 Ford Explorer Discussion 6
B 6F55 trans drain and fill Stock 2011 - 2019 Ford Explorer Discussion 3
G Does keeping a key FOB shielded drain the battery? Stock 2011 - 2019 Ford Explorer Discussion 7
G Parasitic battery drain with lift gate and door open? Stock 2011 - 2019 Ford Explorer Discussion 7
K Heck of a time unclogging sunroof drain Stock 2011 - 2019 Ford Explorer Discussion 6
G Liftgate Drain Hole Cap Stock 2011 - 2019 Ford Explorer Discussion 4
A Cooling fan keeps running drain the battery! Stock 2011 - 2019 Ford Explorer Discussion 35
L 2016 Ford Explorer PTU Drain Plug Size Stock 2011 - 2019 Ford Explorer Discussion 7
K Transmission Drain/Refill & Misfires Stock 2011 - 2019 Ford Explorer Discussion 3
G Securicode (Keyless Entry Pad) Battery Drain Stock 2011 - 2019 Ford Explorer Discussion 8
S 2013 Explorer XLT - Parasitic Battery Drain Stock 2011 - 2019 Ford Explorer Discussion 12
E Anyone using magnetic drain plugs? Stock 2011 - 2019 Ford Explorer Discussion 5
T PTU drain Stock 2011 - 2019 Ford Explorer Discussion 1
J Where are water drain holes in rocker panels for 2013 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 1
deewan Faulty SYNC/APIM causing battery to drain??? Stock 2011 - 2019 Ford Explorer Discussion 16
Similar threads
