wpurple
- July 16, 1999
- CT
- 97 Explorer
This pretty much sums up most of the misunderstanding about ethanol when used within the context of modern vehicles. For example, ethanol does not generate more heat.when it gets cool it turns to gum in fuel system, clogs fuel filters, burns pumps up faster, it doesnt burn evenly, it costs more, can cause detonation in older vehicles it costs more, fouls out spark plugs, generates more heat, and just overall sucks
SOmething else for us to read: a summary by NREL of the study performed by Argonne National Lab (Dept of Energy) concludes that Ethanol requires less energy to produce, the opposite for petrol. It also compares studies done by others and where they fall in the net output vs input scale over the years :Actually you got that a bit wrong.
Ethanol contains 76,500 BTU (1 gallon)
The amount of energy it takes to make ethanol is 98,000 BTU (1 gallon)
This includes the energy to plant, harvest and produce the fuel.
This is an article everyone should read.
Getting Hosed at the Pump
Adding ethanol to fuel is meant to satisfy politicians' desire, as they tell it, to cut air pollution and reduce the nation's dependency on foreign oil, especially oil imported from unfriendly areas of the world. Ethanol does neither.
www.ethanolmt.org/images/argonnestudy.pdf
Ethanol is by no means a perfect energy source, but one thing it does alleviate is the dependence on foreign oil. Think of it as a stepping stone towards a more ideal source of energy that is produced 100% "in-house" instead of overseas.
Are there valid reasons why almost everyone seems to be "down" on ethanol use as fuel?
After all, alcohol WON every single Indy-500 Race for years and years, until Ford won it using gasoline in around 1963 or so. (gas illegal there before).
What are the REAL facts? imp
For the same reason you stated Bob - the influence of the industry over the government. Its not so much that the oil industry is "in bed" with the government, the government "is" the oil industry. So contrary to popular belief about "free market", the market is not always driven by the consumer. Sometimes, the producer, through various forms of tactics such as lobbying, becomes the driver and dictates which path society goes down on.IZ, if you believe the Government propaganda reports about ethanol then you must ask yourself, why are we using crude oil for fuel when we can produce ethanol for 40% less? According to that government study ethanol should sell at the pump for about $1.75 per gall.
Your arguement over subsidies is one sided. You forgot to mention that oil is also subsidized (estimated at $15 to $35 billion a year). This is why our gasoline is much cheaper than overseas. So would you rather have your tax money subsidizing American farmers, or the "multinationals" (which, as a label, opens a can of worms when you factor in labor standards, safety standards, ethics, and so on).Last year about 10.6 billion gallons of ethanol were produced in this country to be used as fuel. The US government subsidized that with about 12 billion dollars. Another 5 billion was given to farmers and refinery plants as start up grants
...FYI Indy cars burn pure Methanol, it has an octane ratio of 114 but has a low energy content. So it burns cooler, but at a ratio of 6.42:1 they suck up mass quantities of it.
