smallwwb
- October 10, 2010
- Seattle WA, Cambria CA, Tucson AZ
- '93 XLT
I've read the posts here about improving ride quality, etc. and have some questions.
My 93 XLT rides not-so-good. Little bumps in the road rattle the teeth. The biggest problem is very excessive body roll, and the rear bottoms out on potholes. There is also a bad sounding clunk that comes from the front left wheel on bumpy roads, expecially when braking. The front tires are wearing bad on the inside. I have looked underneath myself and can't see anything that seems to be loose, or any bad bushings. I've had 2 shops look at it as well.
Has Firestone Destination LE tires about 5 years old with 20k with good tread still, stock 235/75/15, usually inflated to 35psi.
Monroe shocks: one level below sensa-tracs, about 10k on 'em. (This helped a bit)
Not sure about Radius Arm bushings?
I had the TTB bushings replaced recently- the ones that bolt the torsion arms to the axle/frame, but I don't know exactly where to look for the radius arm bushings?
My rear leafs are less than an inch off the overload springs. Rear sits about level with the front when unloaded.
Wheel bearings were replaced recently, about 10k miles.
I would really like to get better ride quality out of this vehicle. It is in top shape other than the suspension, low miles, and was given to me for free.
I spend about 5% of the time on bumpy, dusty dirt roads, the rest on bad pavement.
