samrebel
- April 20, 2004
- Cincinnati, OH
- 1996 XLT
Hey guys, a few more questions. One, I just bought all new Moog 2wd front end parts (balljoints, entire upper arms, tie rod ends, etc.) for my 2wd, can I use them if I go 4wd? Also, is the V-8 swap basically plug and play, or do I have to splice harnesses, swap out radiator, coolant overflow tank/windshield washer tank, brake booster, etc.? If the donor vehicle is 4wd, can I use it in my 2wd without the transfer case, front differential, etc.? Is there a way to have dual pipes on an explorer without hacking up the floorpan or moving the gas tank? Finally, I think I am right that 5.0 explorers used roller cams, can I use a flat tappet cam in it? Does any aftermarket cam manufacturer make roller cams for the explorer 5.0? Is the E303 best for low-end torque? (for towing.) How do I know if a camshaft listed for 5.0/302s uses the 1-3-7 firing order?
Thanks,
samrebel
Thanks,
samrebel
