Motor & transmission interchangeable on a 95 Aerostar with E-4WD & 94 Explorer 4WD?
mdave1956
knoxville tn
2005 Explorer
:salute: Will a 1994 Explorer A4LD 4X4 work in a 1995 Aerostar E-4WD? I found one with the 4.0L motor for $450. It has 120,000 miles. I can hear it run and drive it. What do I look for. Thank you. :thumbsup:
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
They are interchangeable if you have a 4.0L OHV engine like the Explorer. The 3.0L bell housing is different. The extension housing on the transmission is the same on both the E-4WD Aerostar & 4WD Explorer.
mdave1956
knoxville tn
2005 Explorer
yes I have the same motor too sorry I miss spelled the heading I should have said 1995 aerostar with A AWD what should I look for when I look at it don't have the money to be wrong about it
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Make sure that the transmission fluid is red (not black), and does not have a burned smell. Check the seals for leaks. You could check the bands with a torque wrench to make sure that they are not broken. Be careful not to break them in the process. Check the vacuum line going to the modulator for leaking transmission fluid.
mdave1956
knoxville tn
2005 Explorer
OK thank you will do Oh theres a modulator on it I didn't see any on mine but I didn't look good
BrooklynBay
Staff member
Moderator
Brooklyn, NY
tuckman
Elk Point, Alberta
92 Explorer XLT
I ran into an issue when I swapped my A4LD from a 95 aerostar to a 92 Ex. The shift arms are different and had to be swapped.
http://www.explorerforum.com/forums/showthread.php?t=273041
I will be adding pics to that thread soon to help it make more sense.
Other than the shift arm, the trans swap was straight across. Also the motor swap would be straight across.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
I could move that thread into this section since it has to do with Aerostar/Explorer compatibility if it's OK with you. Sometimes people come into this section to see what they could swap between both vehicles.
tuckman
Elk Point, Alberta
92 Explorer XLT
Sounds like a good idea
