MPG Drop? | Ford Explorer Forums - Serious Explorations
MPG Drop?
what kind of mpg drop would i be looking at from going from stock be goodrich rugged trail 245/60/17 to 265/70/17's nitto terra grapplers.
vs.
stock to 275/60/17 or 285/60/17 (if they will fit) Hankook Ventus RH06.
i lost about 4mpg going from stock size bridgestone duelers to Mickey Thompson X-Terrain 33x12.5, and thats mostly driving under 50mph. You shouldnt have too great of a loss.
gears make a big differnace(what is your stock gear ratio)?
That is only a slight change in tire height so it shouldn't hurt you much if any.
265's are the equevelant of a 32 or 31.8 right? then you would loose alot of MPG with 285's it would be even worse and your speedo will be off a bit.....if your primairly a "in town truck" it shouldnt be to bad...i belive hartman is running 32's with 3.55's....but 285's will really suck.
