mechanic021
- March 15, 2004
I have a mtx thunder amp that i just bought maybe 2 months ago if that and its starting to shut on and off on me when i turn the bass up loud. When it turns off the short circuit light will flash on really dim once in awhile so I looked at all my wiring and couldnt find a problem. I also checked all my connections and checked the sub woofer out really good and couldnt find anything that would cause a short. Is there anything else I can check before I have to send the amp in for service? I dunno if this will help or not but the sub itself is like 5 years old so could it be shorting out internally where i cant see it? thanks for your time. Forgot to mention when the bass is on low volume it works fine it only cuts out when its turned up high.
Mike
Mike
