DjDom
Moderator Emeritus
- September 11, 2011
- Toronto, Ontario
- 97 XL(imited)
I finally found someone to scan and find my ABS codes.. 8 years later.
Anyway, here's what I got:
C1185 - ABS Power Relay Output Circuit Failure
C1155 - Left Front Wheel Speed Sensor Input Circuit Failure
C1096 - Pump Motor Open Circuit
Basically, where should I start? I know the front left sensor is good, so the wiring somewhere must be bad. I can trace down the problem for that, but what about the other 2?
Thank you all,
Dom
Thank you all,
Dom
