emothug1985
- April 8, 2015
- 1993 explorer
1993 4.0 5 speed. Less then 60k original miles. Been having idle issues since I got it. On cold start it idles high for a second or two then drops flat and usually dies. If I feather the throttle for a minute or two I can get it to idle enough to stay running while it warms up. But while doing this the idle surges for awhile then usually levels off at really low idle. I had to adjust the bolt so it wouldn't die. And driving it when I come to a stop sign or light the idle stays high,between 2 or 3 k. Then will fall flat after half a minute or so. It has great power and good mpgs. I finally pulled the codes after checking all vacuum lines and doing full tune up and have 122,157,172,176,181 and 211. I did these all KOEO. I did however do a spray test with carb cleaner and it seems to surge rpms when sprayed close to the firewall side of the lower intake manifold. So I'm changing the gasket and will be cleaning the MAF tomorrow after work. I have changed a few sensors and cleaned the TB. It seems like all these codes could be related. I hope? Anyways any insight is appreciated.
