Multiple Codes | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Multiple Codes
sheltonfilms
Hoover, AL
2013 Limited 3.5L
My brother in law has a 2002 Explorer 4.0 (K engine) and his truck is throwing the following codes:
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean
Below codes are pending codes:
P0153 - Oxygen Sensor Circuit Slow Response (Bank2, Sensor1)
P0172 - System Too Rich Bank 1
P0174 - System Too Lean Bank 2
Most of these suggest the Bank 2 Sensor 1 is the culprit, but what is throwing me off is the P0172 code. Maybe its just a coincidence.
What do you guys think?
Is the truck running poorly, or normally? imp
He has complained that his gas millage has gone down significantly.
I erased the codes and the pending ones didn't come back, so they must have been one time occurrence.
I went ahead and changed the HOS2-2,1 sensor, so lets see how it reacts after a few drive cycles.
I'll post results after a few days of driving.
As I understand things, if an intermittent fault occurs rarely, it will not likely throw a code, something like a hundred or more repeat "trouble sightings" of the same type must occur to repeat throwing a code.
So, if something's sticky, now and then, like an EGR valve moves OK, then doesn't one time, then does, no code thrown. imp
Update: No more codes so the O2 must have been bad or degrading.
