jab0106
- April 4, 2008
- Greenville, NC
explorer with check engine light and O/D off light on scanned:
PO171 BANK 1 LEAN
PO174 BANK 2 LEAN
PO741 TCC SYSTEM MALFUNCTION
P1506 IDLE OVER SPEED ERROR
P1740 TCC INDUCTIVE SINGINTURE MALF.
WAS TOLD ONE WAS INTAKE MANIFOLD LEAK, REPLACED INTAKE MANIFOLD GASKETS. CODES CLEARED.
NO NET CHANGE IN CAR SYMPTOMS:
Rides Smooth 1/3 Time
2/3 Time O/D light flashes and following occurs:
Rough, variable idle [mainly low]
Choking off while in Drive
Hard thump @ 1/2 gear change [consistent symptom, others more recent]
O/D light occurs intermittently with no noticeable cause other than possibly reaching gear 4. Some days light is on @ 1st crank; other days light comes on only upon reaching cruising speed approx. 60 mph for a mile or two. O/D light also cuts off with no noticeable cause, usually after riding below 60 and above 20 for an extended period.
WOULD LIKE TO KNOW ALL FIXES, BUT MOST IMPORTANTLY THE QUICKEST ROUTE TO KEEPING CAR CRANKED [service said idle motor probably needs replacing, but that intake manifold gaskets could cause that code--obviously not the case]. CUT OFF TODAY WHEN SHIFTING P TO D.
Any and all help appreciated.
PO171 BANK 1 LEAN
PO174 BANK 2 LEAN
