The factory sized MAF, fuel injectors, fuel pressure, and throttle body are close to perfect for the stock RPM range. Changing any of those by a large amount will not create a positive affect.
The 24 l/hr injectors are completely unnecessary for anything but a major air flow increase. Changing to any throttle body or MAF, or air cleaner(not intake), will not create a major air flow increase.
This is not a Mustang forum, even though there are a lot of novices here who may be influenced by similar "bigger is better" erroneous thinking. Go read a few thousand magazines since the early 90's of the 302HO engine's existance. The ideal sizes of the above mentioned parts have already been tested and retested hundreds of times.
Please do not suggest that you have learned something that no one else has in these past 20 years about the SFI Ford 302 needs. Stay with virtually stock air inlet parts on the 96-01 Explorer 302, unless you are actually changing major parts, such as heads, camshaft, and intake manifold. The MAF sensor and throttle body have the least affect on air flow of an engine so well developed. Those two can be made slightly larger without much harm.
The stock throttle body is virtually perfect for the stock parameters. Some have suggested a slight gain, fine they spent a couple hundred dollars and gained a couple of horsepower, great.
The MAF in stock size does a great job, and a larger size will do equally well, but still again only a couple of HP might be gained. That still is not worth the effort or money spent.
For those looking for real improvements, look elsewhere. Hundreds of people have discovered where money is best spent. Work on the exhaust, all of it. Change as many of the various fluids to synthetic fluids, check out Al's mileage thread. Keep very high quality filters, plug wires etc. in it.
For real HP gains, the only viable solution is to start saving money, and plot on changing heads, camshaft, and even compression if you can afford it. For the cost of a complete stroker short or long block, if you need a new engine anyway, there's a big HP improvement. Good luck
