X-Box
- March 24, 2002
- Hollywood, Fl
- 99 EB V-8
Hey everyone,
Well I've taken the truck to the track and then to the dyno. and here are the results......
Track 14.95 sec @ 92.01 mph @ 4300lbs.
A HP Calculator results:
Using trap speed I get 261rwhp and 308 flywheel
ET gives me 253rwhp and 299 flywheel
The dyno reads approx 230 @ 5200RPM (I pulled the superchip before the dyno run because of detonation)
Where is the problem? Shouldn't this setup have a few more ponies?
I've seen a few engines for sale on-line from performance shops claiming upwards of 430 HP(flywheel)with similar components and carb instead of FI. The truck still has the stock MAS,fuel pump, and 19lb injectors.
I bought a Powerdyne 6lb supercharger. I'm also negotiating a deal on a TFS Track R intake.
The Powerdyne comes with a 200lph in line boost-a-pump.
Is that enough?
I know I need to change the MAS, injectors, and probably the throtlebody.
I think I should go with an 80mm Pro-m and 30lb to 36lb injectors. My truck is a 99' with a returnless fuel system.
Should I convert it to a return system?
Some people are telling me I can't use a Pro-M from a Mustang. Is that true? ie.. C&L
My mods to date are:
FMS 347, TFS Aluminum heads 2.02/1.6, 1.6 Roller rockers,FMS E-303 cam,FMS headers, True 2 1/2" mandrel bent exhaust with no-cats and a 50 series Flo-master.
Sorry for the ramble, it's just this has cost a small fortune and it's not as fast as I thought it would be.
Any input would be greatly appriciated on what mods to go with so I can run 12's w/o NOS.
Thanks. Dom
Is that enough?
Thanks. Dom
