  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
my 97 ranger sas,302 powered.
92explorer5speed
bend,oregon
92 XLT 5spd
ok,i just bought this,its technically a 92 frame,with a 97 body on it,i just trailered it home sunday.
i havent had much time to go over it,but the few things i do know...it needs a better front axle. the entire drivetrains from a 67/68 bronco
d30 front/9inch rear/302 and c4 trans with a dana20 i beleive tcase,its a cast iron case,very very closely resembles a NP205.
it needs ALOT of work,but i got a pretty good deal on it,i paid 700 for it as you see in the pics.
it also needs new springs all around,mainly,the front leaves are 6 inch {rear} ranger lift leafs.and they sagged quite a bit under the weight of the 302,and the rear is SOA conversion with i beleive 4 inch lift leafs,and 4 inch blocks,id prefer to just get taller front and rear leaves to level the truck out,and to get rid of the rear blocks.
heres some pics i took sunday night when we got it off the trailer..
currently it has qr78 buckshots on it,equivalent to a 36 inch tire...the previous owners had 39.5s on it efore they bought the new front leafs,i guess thats when they realized they screwed up and got too small of a lift spring.
the 302 runs,i gotta get the carb rebuilt and the damn starter changed,which requires at the minimum dissasembly of the pass side header/collector to get enough room to get the starter out.
i know it needs quite a bit of attention,but i dont think i did to bad for 700 bucks.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
yep needs work!! Looks like a GREAT place to start though, an Earlybroncoranger!!!
Its likely that 289 makes less power then the OHV 4.0L however, unless its got mods!
nice truck for $$$$$$$ good job!
plans?
92explorer5speed
bend,oregon
92 XLT 5spd
the motor has,hooker headers,2.5 inch true dual exhaust into flowmaster 10 series race mufflers,ported heads with edelbrock intake,msd ignition,pertronix electronic ign conversion,and a small comp cam with crane roller rockers. i was told the motor was from a 68{which was the 302} but the rest was from the 67.
right now my plans are to get the right leaf springs under it to level it back out,fix the few things here and there that need attention,put the rollcage into it,and wheel the PEE out of it.
im ordering a set of 38.5s for it,just not sure which ones i want yet,TSL SX'S or boggers.
heres a pic of my explorer
redranger4.0
Salem CT
2000 Ranger XLT
38.5's on a d30 /stockEB9" =
92explorer5speed
bend,oregon
92 XLT 5spd
neither axle is staying in this truck,the rear is getting the 14BFF i have as a spare for my chevy pickup,the fronts getting either a D44,or A D60 {if i can find a d60 local}
redranger4.0
Salem CT
2000 Ranger XLT
yea that will be a nice rig when those tires and axles are in
TarHeel085
And den
Raleigh, NC
'99 Sport 4wd
looks good man!! thats a hell of a deal on that truck!
nice saab, is that ur too!
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Hell of a deal for a mostly done wheeler. FYI i wouldnt drive it on the front D30. I couldnt see a close up but it appears to have a something welded to the passenger side knuckle for high steer.
Either way, you got a damn good base to start with. :thumbsup:
92explorer5speed
bend,oregon
92 XLT 5spd
well,it apears a motor swaps in order now,good friend of mine just totalled his 04 cobra.... :D
hes alright,insurance totalled it out,but he bought it back,hes givin me the motor/trans for 1200{im helpin him get a new car}
so question is....what kind of trans should i run behind this thing? id love to run the T56,but im not aware of any adapters to boltup a tcase to it.
and this is the 4.6 dohc supercharged 390 horse motor. should make this ranger a freakin riot!
'97 V8
ft. knox ky
'97 mounty 5.0 4x4 baby!!
its definatly doable. Make sure you get all the wiring harnesses and everything from that car. take its computer hell take the gas tank and its lines.
Rallytruck69
Indio Ca
97 Sport, 89 Ranger
atlas make a divorced transfer case now
they didnt when i was looking for mine
so you can use a two by trans and clock the transfer case however you want
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
For the time being, I'd take out the overload leaves in the front if the ride is a little harsh...would help out the flex a little too.
Rallytruck69,
If you ever want to wheel sometime let me know:thumbsup:
You going to the big run next month? Should be a blast out there at Truckhaven.
9 here is my sas ranger on 35's Solid Axle Swap Registry 4
R List of Useful Threads Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Solid Axle Swap Registry 31
B 1999 Ranger SAS (Dana 44/Ford 9 Inch) Solid Axle Swap Registry 18
N '91 Ranger XLT SAS Solid Axle Swap Registry 2
S 92 ford ranger sas Solid Axle Swap Registry 9
J johnny5_72's 89 Ranger Dana 30 SAS Solid Axle Swap Registry 30
S S10slayer's 99 ext cab ranger sas on 36s Solid Axle Swap Registry 12
S '97 Ranger SC, D44 SAS... Solid Axle Swap Registry 9
G Grape Ape SAS .. finally!!! '97 Ranger Solid Axle Swap Registry 20
R ReDLiNeZL's S.A.S. 96 Ranger 4 Banger Mud Bog Truck Solid Axle Swap Registry 15
C Full width Dana 44 and 8.8 under Ranger Solid Axle Swap Registry 55
R 1993 Ranger D44 swap Solid Axle Swap Registry 27
R New to the forum and have sas'd explorer Solid Axle Swap Registry 9
S SAS Mountaineer undrivable Solid Axle Swap Registry 29
johnny499 '98 mountaineer v8 hp44 sas soa on 35's Solid Axle Swap Registry 7
2TimingTom '97 XLT Dana 30 SAS Solid Axle Swap Registry 24
1 1-MEAN-X's '01 Sport SAS Registry Solid Axle Swap Registry 11
01STrunner 01STrunner's Sport Trac D44 SAS/SOA Solid Axle Swap Registry 79
S 98 sport SAS help Solid Axle Swap Registry 1
D 94 ex sas Solid Axle Swap Registry 13
janderson4010 bronco II 3link d30 sas Solid Axle Swap Registry 10
M My SAS 97 Explorer Solid Axle Swap Registry 15
W 99 EB x SAS D44. Solid Axle Swap Registry 55
F 91 sas swap Solid Axle Swap Registry 12
J The Unappreciated X SAS Solid Axle Swap Registry 11
T My 2nd gen ex SAS Solid Axle Swap Registry 31
9 94 Supercab Splash SAS Solid Axle Swap Registry 23
CodePoet 93 xlt sas Solid Axle Swap Registry 7
MEANEXPLODER 91 xlt dana 44 hi-pin sas Solid Axle Swap Registry 17
chad551 2002 Sport Trac SAS Solid Axle Swap Registry 141
L Lifeguards sas registry Solid Axle Swap Registry 23
R Old member first time posting. My SAS. Solid Axle Swap Registry 71
SVO42 SVO42's 1-ton SAS Solid Axle Swap Registry 121
S 93 x SAS Solid Axle Swap Registry 52
D Dangeranger SAS done Solid Axle Swap Registry 29
CheapThrillEX SAS and New Family Wheeler Solid Axle Swap Registry 19
mtwheelin mtwheelins sas Solid Axle Swap Registry 15
IZwack IZwack's SAS Registry Solid Axle Swap Registry 10
F Fat Cat's 99 SAS Solid Axle Swap Registry 80
Spas Captain Morgan, '95 D44 Sas Solid Axle Swap Registry 199
Burns 1991 Full Width SAS 44/9 Solid Axle Swap Registry 31
sn0border88 Sn0border88's SAS'ed Solid Axle Swap Registry 23
Stic-o '99 Full width SAS 44/ 8.8 Solid Axle Swap Registry 28
section525 Section525 - Explorer V8 D44 SAS Solid Axle Swap Registry 38
Kirby N. SAS Steering? Buy Mine- Complete with Heims and DOM Solid Axle Swap Registry 0
9 9sport6's Fix aka sas Solid Axle Swap Registry 40
S SAS Pics w/ Questions Solid Axle Swap Registry 53
F FullFootNotch's SAS on 38s Solid Axle Swap Registry 24
-=DaemoN=- Daemon's SAS Solid Axle Swap Registry 30
F littlefoot sas on 38's DONE!!!! complete with baptism pics. Solid Axle Swap Registry 53
Similar threads
