- April 3, 2008
- Gloucester City, NJ
- 98 2Dr,2,000 & 04 4dr xlt
Hall Power Monitor
I decided to go with a 3 wire voltmeter since they do not allow much if any current flow on the voltage sense circuit. The power wire for the volt meter will be hooked up to switched ignition voltage and uses less than .08 amps.
The sense circuit will be hooked up to the hallpower circuit.
I have already installed it but have to post some other pictures first. I redid my custom center console, I wanted to change a few things. The electric radiator fan override switch has annoyed me ever since I installed it. Made it harder to remove and install the center console so I wanted to move it. Also the two switches for the intercooler pump and fan were always a pain when removing the radio bezel which I just had done recently to install some LED's.
So here is some pics of my center console redo.
I picked up a couple consoles to experiment with from the junkyard, still have one left that is untouched.
