TsherryUSA
- March 16, 2019
- Location
- OREGON
- PORTLAND
- 99 Ford Explorer 4WD 5spd
Been working on this build on and off for a few months now. We finally got a chance to take it on a 6 night dispersed camping trip through southern Oregon about a month ago. Things are getting dialed and I wanted to share.
First, some nice photos of the kitchen area:
Okay onto specifics. Did a 2 drawer system 36" deep x ~42" wide to fit between the wheel wells. I used heavy duty 300lbs. rated drawer slides, which at the time of building felt like overkill. After the trip though, definitely worth it. Can set my 7 gallon water on a fully extended drawer no problem. Wood is 3/4" ply sande from home depot. As of now it is unfinished, but I may clear coat it in the future.
I don't have a table saw, so used a circular saw and the kreg straight cut jig. Worked okay. Good enough for me, but I don't know if I'd make and sell these.
Fit test:
Drawers assembled, with fronts:
I anchored the drawers with Harbor Freight D-Ring hardware and tie down straps under the rear seats:
Somehow I don't have a good photo of the the bed insert support, but it follow the methodology of this design from Solid Wood Worx:
This photo also shows the false top that is sized to fit my stove.
I plan on building a second false top for the right drawer, but need some 1/2" ply. For now, one of our cutting boards works perfect as a second surface:
Right now both drawers mostly hold the kitchen. The left drawer holds the camp stove, fuel, cast irons, percolator, plates, and other odds and ends. The right drawer holds other kitchen stuff and emergency supplies.
Next post, I'll go into the electronics and lighting. Thanks for reading!
Fit test:
