My back power sliding window goes down but never comes up.
bubstoy11
iowa
2001 sports trac
got an 01 sports trac the back window went down last sat but would not go back up pulled the back panel apart found that the switch did not give me the up postion replace the switch still did not work could tell that the switch was working on the wiring block with a power probe that i have replaced the motor today but still does not work looking for ideas and a place to download free wiring diagrams the so i can track somthing down unless i actually got a bad brand new motor for it
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
ncranchero
Co-moderator
Staff member
Moderator
Denver,NC
'94 F150 4x4 SWB 4.9L
Grolli
Grand Forks, North Dakota
2002 Explorer Sport Trac
I had the same problem. Wire in the drivers side wire run (plastic cover to the right of the floor mat) had corroded through. Spliced it back together and it has been working since!
bubstoy11
iowa
2001 sports trac
rmcalis u rock dood that i nitialization procedure worked great my hair finally went back to its regular colar its kinda funny though i evean whent back to the ford garadge that i baught the motor from they were kind to me even let me take a wireing diagram book home checked it all out again ordered a new motor come back in check this blog again find the prcedure try it out call them laugh about it and canceled the next motorweird they did not know about it thanks to all your help. bubstoy11
toobadd
New to this site...... just bought a 01 tracker and had back window problem...did the Initialization Procedure and it's now working again....this site rocks aswell as its members....thank you so much people...
A Rear Windshield Sliding window won't power up or down 2001-2005 Explorer Sport Trac 9
T Power Door Unlock Relay Location? 2001-2005 Explorer Sport Trac 0
J No power 2001-2005 Explorer Sport Trac 0
R No power to turn signal switch 2001-2005 Explorer Sport Trac 1
M Power windows sticking 2001-2005 Explorer Sport Trac 5
D Power distribution box connections missing 2001-2005 Explorer Sport Trac 3
J P0301 rough idle no power (already checked spark) 2001-2005 Explorer Sport Trac 3
T 2004 Sport trac xlt power door locks 2001-2005 Explorer Sport Trac 0
A Power Door Lock Issues 2001-2005 Explorer Sport Trac 1
R 2001 Sport Trac No Power Steering 2001-2005 Explorer Sport Trac 1
C Rear vent power window help needed 2001-2005 Explorer Sport Trac 10
D Parasitic battery power drain. 2001-2005 Explorer Sport Trac 3
R FIXED! Odd power window problem-GEM module? 2001-2005 Explorer Sport Trac 20
M Looking for power plant upgrades for 2002 Explorer Sport Trac... good, bad, ugly. 2001-2005 Explorer Sport Trac 1
J Power port rewire to switched type 2001-2005 Explorer Sport Trac 2
H lack of power or gas 2001-2005 Explorer Sport Trac 2
L Low or Zero Speed Shudder in Power Steering 2001-2005 Explorer Sport Trac 8
S Power seats not working 2001-2005 Explorer Sport Trac 1
S Rear power window switch 2001-2005 Explorer Sport Trac 0
C Would like to check connector for power mirror 2001-2005 Explorer Sport Trac 3
Paul Fithian Power Down Back Window Switch Repair 2001-2005 Explorer Sport Trac 2
H Wiring Help...Keeping power locks/windows in a PreRunner 2001-2005 Explorer Sport Trac 2
C Power Rear View Mirrors 2001-2005 Explorer Sport Trac 8
J Power Seat Motor 2001-2005 Explorer Sport Trac 1
2 No power to overhead console and map lights 2001-2005 Explorer Sport Trac 5
O leaking power steering pressure hose 01' 2001-2005 Explorer Sport Trac 1
N Power seat motor toast 2001-2005 Explorer Sport Trac 7
L Power windows has no power to them checked fusesand now the radoi doesn't work can't figure it out. 2001-2005 Explorer Sport Trac 2
H 2002 Driver Door Lock Actuator Unlocks - Doesn't Lock - Has Power 2001-2005 Explorer Sport Trac 13
0 Dead radio, power widows, guages questions... 2001-2005 Explorer Sport Trac 5
V Increase power ? Turbo? Suggest 2001-2005 Explorer Sport Trac 5
K power staying on 2001-2005 Explorer Sport Trac 3
M More Power for an 05 Sport Trac 4×4 2001-2005 Explorer Sport Trac 6
1 2002 power passenger seat conversion. 2001-2005 Explorer Sport Trac 0
J Rear (Bed) Power Outlet 2001-2005 Explorer Sport Trac 4
K Flushing power steering fluid-thoughts on in-line filter? 2001-2005 Explorer Sport Trac 10
K rear driver side power window don't work 2001-2005 Explorer Sport Trac 8
M sport trac power window 2001-2005 Explorer Sport Trac 2
A Yet another power window question 2001-2005 Explorer Sport Trac 1
P 2005 Sport Trac How to Install Power Heated Seats 2001-2005 Explorer Sport Trac 1
O bleeding power steering fluid 2001-2005 Explorer Sport Trac 2
429CJ-3X2 Power source for power seat install? 2001-2005 Explorer Sport Trac 2
K Power mirror switch problems fixed…w/o a new switch 2001-2005 Explorer Sport Trac 0
0 Power Programmer 2001-2005 Explorer Sport Trac 1
P Power Window problem 2001-2005 Explorer Sport Trac 5
H Power door lock problem 2001-2005 Explorer Sport Trac 9
A Power rear window 2001-2005 Explorer Sport Trac 1
N 2004 sport tract power seats 2001-2005 Explorer Sport Trac 0
A No power, Gauges vibrate back and forth. 2001-2005 Explorer Sport Trac 2
C 2005 ST XLT Power Locks 2001-2005 Explorer Sport Trac 7
Similar threads
