psychotic
- February 26, 2002
- Olathe, KS
- RIP: '02 V8 Limited 4WD
Ok so I have the ground-loop whine in my rear speakers (with the pitch that goes up with the RPMs b/c of the altenator)
I want to try and fix this without installing a ground-loop isolator.
Yes the power wire and RCA cables are run down opposite sides.
Here is what i've tried:
I've switched the front and back RCA cables to make sure the whine didn't come from the RCA cables. (because it is only in the back speakers)
-- still whined so it wasn't in the RCA signal
I also just now switched grounding locations for the front and rear amp. The rear still whines, but the front does not.
-- so the grounding spot isn't bad I guess?
The front amplifier pulls more amps than the rear one(25 amp vs 40 amp), if that makes any difference as to why one whines and one doesn't.
I also have another amplifier for my subs pulling 60 amps grounded a couple feet away from both.
Would putting 0 ga wire from the negative battery terminal to the frame help? This is the only other thing I can really think of.... to help make the ground better.
Any ideas??
Any ideas??
