My Explorer Sport 2001 - Workblog
wantedps
2001 Explorer Sport 2dr
Firstly when it was bought it was:
Then i've spent huge amount of $ to fix all the problems including cooling system, breaks, leeking of oil from any place it can leek.
Also replaced the front torsions (found used on the local garage) and added a springs to the back, it start to be a little lifted:
Then i started an anti-rust WAR:
Finally Lifting - 3":
Replaced the fog-lights:
Front hull pads was rusted and weak so they was fully removed and remade from steel:
Radiator was dropped by new steel spacers from the top and bottom mounts was recreated.
Front was painted matte black. Now its a different car)
Thanks to Sogsnakebite for inspiration and help!
To be continued....
Sogsnakebite
St Agatha Ontario
03 sport 4x4
Wow man tons of work good job, and ty for the kind words
Sogsnakebite
St Agatha Ontario
03 sport 4x4
What tire carrier did u have ?
wantedps
Thanks man it's only a start.
The tires now is Avalanche X-Treme 265/70/16 but i plan to install Cooper ST 285/75/16 when my bodylift ll'be finished.
Houston, TX
1998 Explorer XLT
I think he was referring to the spare tire carrier attached to the bumper in the pics of when you got it.
wantedps
I dont have any because the original spare tire carrier is removed by previous owner. I think because rust eaten it)
wantedps
Updated the first post with some new pics...
Sogsnakebite
St Agatha Ontario
03 sport 4x4
Looking good Paul
wantedps
Front painted black. Updated.
wantedps
Which one is nicier?
I've started to rebuild my tail lights because there was NO stop signal on left and right))))
Is anyone have the same? Only Turn signal, back driving light and parking lights???
I will make - Stop signal, turn signal, parking lights and back driving one. Using LED/COB LEDs.
Sogsnakebite
St Agatha Ontario
03 sport 4x4
Bottom one , really digging that
Sogsnakebite
St Agatha Ontario
03 sport 4x4
Very interested in how your doing that
wantedps
You mean the one with three circles?
I will show you in details how i did thatwhen i will finish it for myself.
At now i just bought these COB Angel Eyes http://www.aliexpress.com/item/2Pieces-1pair-Auto-Halo-Rings-COB-60MM-Angel-Eye-COB-Chips-Headlight-45-SMD-Car-Angel/32480912242.html
And now im testing combinations to find the nicier look and better functionality.
I plan to buy a bigger ones in yellow and also filled round ones that smaller that these on the pictures to play with combinations. Then i just will use some epoxy and fix all them inside tail light.
Also plan to make tail light more easy to open, because you need to heat it in the oven for 15min and then open it slowly and not to bend the red lens.
Sogsnakebite, tell me - do you have stop light in your taillights?
wantedps
Simulation:
Which one is better?
Sogsnakebite
St Agatha Ontario
03 sport 4x4
I like the bottom one with 3
J 2001 Explorer Sport can stock intake plenum Handle turbo? Modified 1995-2001 Explorers 10
B 2001 Ford Explorer sport lift kits Modified 1995-2001 Explorers 1
B 2001 Ford Explorer sport v8 and manual swap Modified 1995-2001 Explorers 4
C I want to Swap in a 4.6L 2V V8 into my 2001 Explorer Sport, but I need help Modified 1995-2001 Explorers 8
G 2001 Explorer Sport 5.0 swap/Mustang ECU and T5 questions Modified 1995-2001 Explorers 10
L 2001 Ford Explorer Sport seating? Modified 1995-2001 Explorers 12
E 2001 Ford explorer sport 2 door 4.0l 4x4 body lift? Modified 1995-2001 Explorers 3
Sonny1597 Dana 35 IFS 2001 Explorer Sport Modified 1995-2001 Explorers 13
P 2001 Explorer Sport Modified 1995-2001 Explorers 3
D 2001 Explorer Sport Losing Power Modified 1995-2001 Explorers 3
Q 2001 Explorer Sport with rear glass hinge issues... Modified 1995-2001 Explorers 2
D 2001 Explorer Sport Fenders Modified 1995-2001 Explorers 13
D 2001 Explorer Sport O2 Sensors Whack Modified 1995-2001 Explorers 0
G 2001 Explorer Sport throttle body help Modified 1995-2001 Explorers 0
B Ideas on Lifting 2001 Explorer Sport 4wd Modified 1995-2001 Explorers 4
9 2001 explorer sport 2dr v8 swap Modified 1995-2001 Explorers 35
M 2001 Explorer Sport v6 to v8 swap PATS problem Modified 1995-2001 Explorers 15
S 2001 ford explorer sport 4 inch lift Modified 1995-2001 Explorers 20
R 2001 explorer sport 4x4 question Modified 1995-2001 Explorers 0
D 2001 Explorer Sport Side Marker Install Modified 1995-2001 Explorers 10
R 2001 ford explorer sport 2wd lowering kit Modified 1995-2001 Explorers 3
L 2001 Explorer sport lift kit Modified 1995-2001 Explorers 34
E Yet another lift question...2001 Explorer Sport Modified 1995-2001 Explorers 4
Z Transforming my 2001 Explorer Sport *Ideas* Modified 1995-2001 Explorers 2
J 2001 explorer sport lowered pics? Modified 1995-2001 Explorers 1
T Explorer Sport 2001 4x4 Modified 1995-2001 Explorers 6
C Rear blocks For 2001 ford explorer sport Modified 1995-2001 Explorers 1
A 2001 explorer sport lift kit Modified 1995-2001 Explorers 7
C 2001 Ford explorer Sport Suspension Question Modified 1995-2001 Explorers 2
S 2001 ford explorer sport prerunner Modified 1995-2001 Explorers 1
S 2001 explorer sport lift?? Modified 1995-2001 Explorers 1
M 2001 Explorer Sport 4x4 - modifications to improve fuel economy? Modified 1995-2001 Explorers 18
S 2001 explorer sport rear springs Modified 1995-2001 Explorers 3
1 HOW TO: 2001 Sport Cluster Swap for 1998 Explorer Modified 1995-2001 Explorers 50
S New to the Board - 2001 Explorer Sport Modified 1995-2001 Explorers 0
B Cold Air Intake for 2001 Explorer Sport Modified 1995-2001 Explorers 13
P Matthew LaLonde's 2001 Explorer Sport Modified 1995-2001 Explorers 1
2 Looking for: 2001 Explorer Sport Chrome Gas Door Modified 1995-2001 Explorers 11
O 2001 Explorer Sport 2wd Lift with alignment problem Modified 1995-2001 Explorers 4
4 2001 Explorer Sport 4.0L Granatelli Mass Air Flow Sensor Modified 1995-2001 Explorers 1
O 2001 Explorer Sport Spark Plug Problems Modified 1995-2001 Explorers 3
C 2001 ford explorer sport 2wd lift Modified 1995-2001 Explorers 4
F 2 door 2002 Explorer Sport 4x4 4.0 front lift? Modified 1995-2001 Explorers 2
@ 1999 Explorer Sport Overlander Modified 1995-2001 Explorers 0
B 2007 Ranger Sport wheels on 2nd gen Explorer? Modified 1995-2001 Explorers 1
redavis460 Another 1998 Explorer Sport V8 Project. . .Completed! Modified 1995-2001 Explorers 94
W 95 ford explorer sport 2door - 6” lift? Modified 1995-2001 Explorers 2
JimmyZ30024 2003 Explorer Sport XLT lifted Modified 1995-2001 Explorers 16
WormsExplorer My Explorer Sport Build Modified 1995-2001 Explorers 203
T Lift kit for 2wd Explorer sport Modified 1995-2001 Explorers 3
Similar threads
