My Explorer Sport Build
WormsExplorer
Location
Colorado Springs, CO
Colorado Springs, co
97 Sport 4.0 SOHC auto
I had a build thread going and it had to many explorers that I started and then changed then started and then changed and so on and so on. SO I am gonna start an all new thread and just work off this one. I have a 98 Sport 5 speed Manual that I got from a member here on the forum. Here was the picture I got before I picked her up.
The interior
This was all that I had. Her Rear Axle sitting of the the side. BUT it was for free and I had everything I needed to get her back on the road.
This is what she looked like when I got her home.
What I have done so far. Got 4 door leaf springs and installed them. Put a good rear axle into her and will on the first week of august get the front end completed and fixed. This is what she looks like now.
Plans -
32" tires
Manual transfer
4.10 axles
hidden winch behind bumper
Roof basket
decent radio. (Must have music on the trails)
Right now this is about all that I want to do with her. Once on the trails and see what she is capable of I will see if I need to do more to her.
RandomNerd2000
South Carolina
Meanwhile I was gonna reply to the other thread but it's closed.
Varsity
Don't need no stinkin 4WD...yet
Chicago, IL
'00 Sport
Consider me subscribed :)
WormsExplorer
Location
Sorry sir. Wanted to put it to one thread. Some people were getting confused on what vehicle I was building. I started with a 92, then 93, 96, 97, and now this one a 98 sport. This one though I really like. I think this one is gonna be my build. So far really happy with it. We will see what happens when I take her to the trails.
RandomNerd2000
South Carolina
You'll be happy I think, I had a 2WD SOHC truck that'd go anywhere almost, and my V8 2WD does great too, although the LS clutches are past their prime at 271K. These things flat out are nimble.
WormsExplorer
Location
Ok got front diff installed drive shaft installed and I still do not have 4 wheel drive. Front diff is out of an older year explorer. It has the vacuum connect in the front. I am able to crawl underneath and turn drive shaft and it spins freely. Suggestions please. I think it should not spin freely. If I can hook up the vacuum lines and a switch to turn on when out wheeling I will. But right now I do not have 4wheel drive. :(
WormsExplorer
Location
Well a little update on my Sport.
Got a CB mounted
I also cut some weight a little from her Butt. Yes the Bumper was Painted all Black. :) You can also see my Daughters 97 parked next to her.
And here is another Shot of her Driver Side With my Daughters 97. It is awesome being able to driver her.
Did not get pictures of it but I also got the Front Diff installed. That was a pretty easy job. Now to head to the Pull and Pay Next Saturday and get the Vacuum connections and what not for the Vacuum axle so I will have 3 Wheel Drive as what mountaineergreen did on his write up. She is coming along pretty good. Still have not been able to get good tires for her. I also was able to get a Transfer case for my daughters Ex and gonna get that in some day.,
WormsExplorer
Location
Just a Minor Update. Right now My Explorer has my Daughters Rims and tires on her. They are just 30" tires. These rims and tires have been with me for some time.
I do have a question though. She feels VERY stiff when Driving down the road. Is this due to the TT and 4 door Leaf pack? I actually just used the Bastard pack and put it under the main spring of the Sport. The Shocks in the rear are adjustable ie Hard or soft. The front Shocks are shocks I got From Amazon. Just wondering. I do have a main leaf spring from a 4 door if I need to change out the Main leaf. I do like the ride height though :)
Thank you for the help.
WormsExplorer
Location
OK Question for you all. I did some searching and I guess I am not good at wording it right and found nothing that I can see. But I am wanting to swap to an Auto trans. Is there a build thread for it or would it be to much of an issue to get an Auto into my EX. Love the Standard but wanting the Auto. Old age and knees are not good to me. This is going to be going over rocks for trails. I have driven a Standard over a pretty difficult trail and it was a standard and did pretty good. Just wondering if it is worth it able to.
On another note It does not ride like a tank anymore. I changed out the Main leaf to the 4 door main leaf and it rides pretty good. Now to get her to be 4x4. I put her in 4low and was able to move the Front Drive shaft easily. So I am thinking I need to get a 1354 transfer into her. Or is it suppose to do that. The Front Diff came out of a 95 Ex.
Thanks all.
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
As far as going from manual shift to automatic transmission, for starters you will need the auto shift steering column and instrument cluster indicator, trans/ t-case, torque converter/flexplate, front and rear d.s., cross members/skid plate, ECM and GEM modules, g-meter, ect. ect., should probably find a complete donor vehicle ans switch everything over, it is no small task.
WormsExplorer
Location
Thank you sir. That was what I was looking for. Looks like I will stick to the Stick LOL
RandomNerd2000
South Carolina
The other thing is if you converted to the auto you'd get a 5R55E, which is a fragile trans compared to the 4R70Ws in the V8 trucks. I see your point but I'd stick with the manual
WormsExplorer
Location
Yeah its looking like I will be staying with her as a stick. Maybe after I build her and do what I can might get another one that is an auto. Who knows. As many explorers I've had in the past 3ish years lol
massacre
‘94 Explorer
‘19 Nautilus
Man I really miss my manual Explorer, great gas mileage.
RandomNerd2000
South Carolina
I looked at a 95 Sport manual at one point, trans was shot though, sometimes I wish I'd have bought it, just to have, ah well.
WormsExplorer
Location
Yeah I am really liking this one a lot. My son likes it a lot also. I think the biggest part that he likes is the exhaust. Cause there is no muffler on it at all and it is a 2.5" pipe all the way out from Cats. She is pretty loud. Gonna this weekend install a muffler. Quiet her down a little.
RandomNerd2000
South Carolina
It's a dumped 4.0? I bought my 01 XLT dumped underneath it, that thing sounded AMAZING, loudest 2nd gen I've ever seen. It needed a bit of exhaust though because it was audible half a mile away and I put stock stuff under it and had it all welded up and sold it.
WormsExplorer
Location
It goes out just behind rear Passenger tire. But yeah No Muffler at all. I am still not understanding my transfer case though. I put it in 4 low I can still move my Front Drive Shaft with my hand. It is in Gear and it is still movable. It that suppose to do that?
974X4BLACKSPORT
Location
FL
hudson
Please explain how you can reach the front driveshaft from the driver seat.
