My Free 89 BII | Ford Explorer - Ford Ranger Forums - Serious Explorations
My Free 89 BII
Free89BroncoII
Bremerton WA
1989 Bronco II
Ok.....I decided to post my build up here and see what everyone thinks.
I recieved this BII for free from it's original owner in excellent shape. Here is what she looked like upon getting her home.
Free89BroncoII
Bremerton WA
1989 Bronco II
Soon after getting her home she got some clear corner lenses and a 3" Performance body lift.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
that is a clean truck for free!!
If you come across any more let me know! hahaha
Free89BroncoII
Bremerton WA
1989 Bronco II
Next on the list was a 4" Lift Kit. Now I had never done a lift before but besides being a little time consuming, not really that bad. For wheels and tires I went with 15x10 Unique Street Locks with Super Swamper 33x13.5x15 LTB's
Free89BroncoII
Bremerton WA
1989 Bronco II
Next on the list was a Midland CB. I mounted the antenna right off the spare carrier and CB under the dash.
Free89BroncoII
Bremerton WA
1989 Bronco II
I had ordered a steering stabilizer that was on back order for 2 weeks, when she arrived she was on in no time.
Free89BroncoII
Bremerton WA
1989 Bronco II
Now not being a big fan of chrome bumpers, I had decided to buy a JD front bumper and had actually found a rear in a classifieds section. I test fit it to get it where I wanted it to sit, then primer, and paint.
JoshC
Only rolled it once honey
Culloden, WV
97 4d OHV
Wait a minute, you got a free B2 4x4 and it's not even a rust bucket, what the crap! Nice one man!
That looks really nice and it makes those 33's look small!
Free89BroncoII
Bremerton WA
1989 Bronco II
Shorty after the front bumper was complete I bought a Surco roof rack and a Hi-Lift Jack to bolt up in her. I also used a prop to hold the rear bumper to fill the body lift and make rear bumper templates.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Your camber is +
If you get that fixed it will drive 100 times better, handling wise.
Your tires are not going to last at all with + camber and the bump steer is horrible.
I assume you have installed alignment shims already?
It is possible you will not be able to get the camber corrected to 0 without the use of taller axle pivot drop brackets.
Can we see some details on your 4" lift?
I put my cb antennea is a very similar spot
Plan to beef up the rear tire carrier/swing and re-enforce the fiberglass on the hatch catch piece, with a 33" it will rip the fiberglass and bounce all over the place.
Get that rear bumper on! the Duff bumpers are awesome, my rear has been hit by two cars and MANY rock ledges, it also tows the boat/anything nicely, with a body lift and bumper brackets dont try this or be really careful! (depends on the brackting you come up with). I see extended radius arms in your future, and gears.
Gorgeous BII, now I know what it looks like with round lights on the top tabs, thanks! (I have KC square ones that will go there with a quick release)
Free89BroncoII
Bremerton WA
1989 Bronco II
This is when disaster struck. First full day on the road and the motor decided it was time to retire. Option 1....rebuild, or option 2....5.0. Hmmmm......
So, I bought a longblock 5.0 out of a 92 Stang GT and decided to do a full build. I am still in the process of this build but heres what I so far. 92 5.0 Block and crank, Forged pistons, Edelbrock Heads, Edelbrock intake, Holley Truck Avenger Carb, MSD ignition, Duff Headers, and so on
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
what trans and T case will you run?
How long is all this taking?
You are going to love the V8 BII, I am guessing you aready know your stock axles may not hold up very long
Free89BroncoII
Bremerton WA
1989 Bronco II
Here's where we are right now. I pulled the gauge assembly and gutted the factory gauges. I now have bought all Autometer gauges, speedo, tach, fuel, volt, oil pressure, water temp, and trans temp. I'm getting ready to build the gauges along with a pillar for the extra gauges. I'm also getting ready to pull the frame to spray it with POR-15 that I have left over from another job. As far as the alignment...thats as fas as she goes. Since I have to pull the chassis Im looking for some 6" front brackets if anyone knows where to locate some. I'm getting ready to take vacation to get some more done so I will get some new pics up very soon....
Free89BroncoII
Bremerton WA
1989 Bronco II
Right now I have a Dana 35 and a 8.8 with 4.10 gears waiting for me to pull the chassis. As for trans and t-case I have a C4 and am looking for a Dana 20 to buy. As for time, it took about 4 months to get this far....financially things have slowed down a little but are picking up again.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
I have seen pivot brackets for sale on this forum.
Here's how the TTB works
You can use 4" brackets with a 5.5 or soft 6" coil, use the max degree shims to correct camber
you can use 6" brackets with a 8" coil
You have to be careful here because many 4" lift kits actually come with a 2" drop bracket (measured compared to factory) and rely on shims to correct camber, so putting a 6" coil on some 4" brackets will still leave you with + camber and no way to correct it.
With the C5 and dana 20 its going to be a monster, I figure you will install a low gear set in the dana 20?
I plan to convert my current BW 1354 to a dana 20 twin stick eventually, this requires me to convert my auto trans output, again hahaha
You are building a monster, nice!
Free89BroncoII
Bremerton WA
1989 Bronco II
Thanks Josh....for some reason I come across BII alot. I can't wait to get this done due to I want an X with plans of a SAS....straight trail rig.
Free89BroncoII
Bremerton WA
1989 Bronco II
Thanks 410....
I'm looking for true 6" brackets so I can get a little more lift. I know the 5.0 won't weigh the front too bad and I also need to do some work on the rear.....bad leafs. As far as the t-case, yes, low gear and twin sticks.
JoshC
Culloden, WV
97 4d OHV
Cool! :biggthump Looking forward to the rest of the build!
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
my front end sagged about .5" with the 5.0 over the 4.0L I figure its mostly because I have a full size transmission and I run soft Skyjacker 6" coils (350 psi)
Free89BroncoII
Bremerton WA
1989 Bronco II
Yeah, my plans are to run 6" brackets up front, but still unsure of the coils I will be using.
