Brian1
- February 2, 2000
- Albuquerque, NM
- 1991 XLT
- Callsign
- KG5BAQ
My new front winch bumper (Added more pics)
Update - More pics below in another post
Here it is:
With the winch:
I wanted a new front bumper to replace the flimsy stock one. It needed to be a jack point for a hi-lift, hold a winch inside it, have tow points integrated into it, not stick out too far and it needed to look good. I did a little research and found a bumper design I liked. The bumper I liked was made by Bulletproof Mfg. for a Jeep XJ. I also saw LimitedEx had a bumper similar to it on his Explorer so I asked him for a few dimensions. I ordered the metal and began to fab my new bumper. It is made of 2"x6"x3/16" box tube, 3/8" mounting plates, 1/4" ends and center, 1"x2"x1/8" outside reinforcement links and 2- 1"x3" tabs for the shackles. The pieces were all cut and are fully welded. I made the plates with 2 sets of holes for stock height and 1" BL height so it would be adjustable. It attaches to the frame with 3ea. 1/2" grade 8 bolts per side. I have a Warn XD9000i that I want to mount inside of it in the future but for the present time I needed my bumper to support a multi-mount setup. I made a receiver hitch that bolts inside the bumper to the frame attachment plates. It is fully gussetted and uses 2ea. 1/2" grade 8 bolts per side to attach it. The outsides are reinforced with a piece of 1"x2"x1/8" that runs back and bolts to the frame. They are flange mounted for easy removal/installation of the bumper.
Edit: The winch cradle is also home-made. It was designed to look like Warn's but has a few different features. It is made of 1/4" steel and is gussetted. The handles bolt on and are 1/8" x 2" with a pipe (electrical conduit) welded in for the actual handle.
Here are a few more pics:
Bumper completed just needs paint:
And 1 last pic of it installed:
In the future I am considering adding a brush guard that would bolt on or a small stinger bar which would also bolt on.
I will have additional pics of the winch attached later when I get them developed.
Here it is:
With the winch:
